Re: DMVPN with VRF..
y_ananthan
Hi Expert,
Recently i try to set-up a DMVPN cloud for one testing purpose. During the test i creat HUB site  DMVPN with VRF config and spoke site with pure DMVPN. But i couldn't bring up the DMVPN. Here i attched my config.  Could you please help me to give the solution..
Thank you.
HUB..
crypto keyring VPN vrf 101
  pre-shared-key address 0.0.0.0 0.0.0.0 key cisco
crypto isakmp policy 1
authentication pre-share
crypto isakmp profile VPN-101
   vrf 101
   keyring VPN
   match identity address 0.0.0.0
crypto ipsec transform-set trans2 esp-des esp-md5-hmac
crypto ipsec profile CUST
set transform-set trans2
set isakmp-profile VPN-101
interface Tunnel0
description DMVPN Tunnel Interface
bandwidth 1000
ip vrf forwarding 101
ip address 10.10.10.1 255.255.255.0
no ip redirects
ip mtu 1436
ip nhrp authentication cisco123
ip nhrp map multicast dynamic
ip nhrp network-id 99
ip nhrp holdtime 300
ip tcp adjust-mss 1360
no ip split-horizon eigrp 1
delay 1000
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 10
tunnel vrf 101
tunnel protection ipsec profile CUST
interface FastEthernet0/0
description Connection to Connection to WAN
ip address 192.168.10.1 255.255.255.252
duplex auto
speed auto
router eigrp 1
auto-summary
address-family ipv4 vrf 101
  network 10.10.10.0 0.0.0.255
   no auto-summary
  autonomous-system 1
exit-address-family
ip route vrf 101 0.0.0.0 0.0.0.0 192.168.10.2
SPOKE..
crypto keyring VPN
   keyring VPN
interface Tunnel0
bandwidth 1000
ip address 10.10.10.2 255.255.255.0
no ip redirects
ip mtu 1436
ip nhrp map multicast 192.168.10.1
ip nhrp map 10.10.10.1 192.168.10.1
ip nhrp nhs 10.10.10.1
delay 1000
tunnel key 10
ip address 192.168.20.2 255.255.255.240
duplex auto
speed auto
router eigrp 1
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.20.1
Peter Paluch
In the HUB router configuration, you are most probably missing the FVRF (Front-door VRF) specification in your crypto profile configuration. Correctly, it should look like this:
   vrf 101
   keyring VPN
   match identity address 0.0.0.0 101
Give it a try and please let us know if it worked. Thanks!
Best regards,
Peter
10 Replies 10
Peter Paluch
   vrf 101
   keyring VPN
Best regards,
Peter
y_ananthan
Hello Peter,
It's working fine.. Thanks a lot man...
-Ananthan
Hello Ananthan,
You are welcome - actually, thanks to you, I have also learned something new while debugging your scenario
You may be interested in reading the following document that helped me to make my mind clear about the FVRF (Front VRF) and the IVRF (Internal VRF), see:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6660/prod_white_paper0900aecd8034be03_ps6658_Products_White_Paper.html
Best regards,
Peter
Hello Peter,
Thanks for the solution.. Actually before i configure i got the guide from that white paper. But i don't have enough experience in troubleshooting Security   ( until now i'm a pure R&S guy) . So couldn't able to get proper answers from DEBUG. But from your suggestion i got the answer and its working well.
Thanks..
-Ananthan
Hello Ananthan,
I am also primarily R&S guy. When I tried to debug your original configuration I needed to have the following debugs on the hub router so it finally told me that the FVRF did not match:
debug crypto isakmp
debug crypto isakmp error
debug crypto ipsec
debug crypto ipsec error
Anyway, I'm glad you got it working, allowing me to learn more as well in the process Take care and good luck!
Best regards,
Peter
Hello Peter,
I got an another issue.. After establish this DMVPN i add another IPSec to the spoke site to another peer                (crypto map CUSTMap).
Here is the sample config..
crypto keyring VPN
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp test123 address 192.168.169.50
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 30 periodic
   keyring VPN
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set esp-3des-sha esp-3des esp-sha-hmac
crypto map CUSTMap 1 ipsec-isakmp
set peer 192.168.169.50
set transform-set esp-3des-sha
match address 110
interface Tunnel0
bandwidth 1000
no ip redirects
ip mtu 1436
delay 1000
tunnel source FastEthernet0/1
tunnel key 10
interface FastEthernet0/1
  ip address 172.20.20.1 255.255.255.0
duplex auto
speed auto
crypto map CUSTMap
the problem is when remove the DMVPN config then only this IPSec is working fine. Once i bring up the DMVPN the IPSec to "crypto map CUSTMap" is going down. Any finding from your end ??
-Ananthan
Hello Ananthan,
I do not quite understand the need for the crypto map on your Fa0/1 interface. Is it there for some other IPsec tunnel apart from the DMVPN? The DMVPN traffic itself, either spoke-to-hub or spoke-to-spoke, is protected using the IPsec crypto profile. Can you kindly explain the crypto map a little closer?
You have not shown us the ACL 110. It is possible that it conflicts with the traffic already encrypted by the Tunnel0 crypto profile. Can you also display the ACL 110?
Best regards,
Peter
Hello Peter,
Yes .. That crypto map under fa0/1 is belongs to another IPSec peering to another router (that router not in DMVPN cloud) . This IPSec purely for management purpose..
Here is the ACL 110
access-list 110 permit ip host 10.10.10.10 host 172.16.16.16
access-list 110 permit ip host 10.10.10.10 host 172.16.16.17
access-list 110 permit ip host 10.10.10.10 host 172.16.16.18
access-list 110 permit ip host 10.10.10.10 host 172.16.16.19
The IP 10.10.10.10 is loopback IP from Spoke router.
Thanks.
-Ananthan
Hello Ananthan,
So far, I do not see any obvious problem with the configuration. I am wondering, however: after the DMVPN comes up, what routes are learned by the routing protocol run over the DMVPN tunnel? Is it possible that either the 172.16.16.16-19 or the 192.168.169.50 becomes routed through the tunnel and not directly through the Fa0/1 interface?
We have to verify this very carefully - please use the show ip route command together with each of these IP addresses while the DMVPN is up, and check for the forwarding information.
Thanks!
Best regards,
Peter
Hi Ananthan,
Any news with this issue?
Best regards,
Peter
