QoS Output Drops
John Blakley
All,
Is it possible to create your own bottleneck? Here's the problem:
I have an ethernet handoff from our provider. It's a 100Mb link with a 50Mb CIR. I have the bandwidth statement on the interface for 50000 and a service policy that shapes class-default for 50Mb. We have TONS of output drops, but the circuit hasn't been above 35Mb. I'm wondering if going from 100Mb (inside) to a bandwidth of 50Mb (specified on 'outside' interface) is causing the router to see it as congestion. Even if, why would I be seeing tail drops if I never reach above 35Mb?
policy-map COS
class HIGH
    priority 6000
  set ip dscp ef
class MEDIUM
    bandwidth remaining percent 60
  set ip dscp af31
  service-policy MARK-BGP
class LOW
    bandwidth remaining percent 30
  set ip dscp af21
class class-default
    bandwidth remaining percent 10
  set ip dscp default
     random-detect
    shape average 50000000
  service-policy AVPN
interface FastEthernet0/0/0
bandwidth 50000
no ip address
duplex full
speed 100
service-policy output COS
QoS Set
        dscp default
          Packets marked 220722492
        Exp-weight-constant: 9 (1/512)
        Mean queue depth: 18 packets
        class     Transmitted       Random drop      Tail drop          Minimum        Maximum     Mark
                  pkts/bytes     pkts/bytes       pkts/bytes          thresh         thresh     prob
        0       220089486/172146352525 554475/476267172  90761/75634968          20            40  1/10
John
HTH, John *** Please rate all useful posts ***
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Your posted stats shows "Mean queue depth: 18 packets".
How are you "seeing" never more than 35 Mbps?  Reason I ask, shapers, policers, WRED work at a much, much, much finer granularity than something like even 30 interface stats.
There's a good change your WRED (default) thresholds are much too restrictive for 50 Mbps on a MAN/WAN.  Suggest you remove WRED altogether.
Joseph W. Doherty
Disclaimer
Posting
Our bandwidth monitoring server is only showing about 17Mb at the moment. I'm going to remove WRED and see if that helps.
Thanks!
