Re:IP static route summary query
ambivert skill
In my Lab environment in GNS I have connected two 7200 series router through fastethernet on router A I have given IP adress 192.168.10.54 and router B I have given IP address 192.168.10.53 and default route as 0.0.0.0 0.0.0.0 192.168.10.53 and when I run the command on router A it shows result as follows  "C  192.168.10.52/24 is directly connected ,Fast ethernet 2/0".
So I need to know why it's showing the result of .52 at last why not .53 or .54 at last what is the reason it's showing .52 which I have not mentioned in my IP address.
HI Ambivert,
Then thats the correct thing you are seeing. I have showed this to you on my previous update:
If you are using the /30 then the subnet would be displayed.
R1(config)#int f1/0
R1(config-if)#ip address 192.168.10.54 255.255.255.252
R1#show ip route
     192.168.10.0/30 is subnetted, 1 subnets
C       192.168.10.52 is directly connected, FastEthernet1/0 <<<< 52 is displayed.
In your scenario:
10.255.222.52 is the subnet and followed by the host ids.  ( 10.255.222.53 & 10.255.222.54 will be the two host which can be on .52 subnet hence it only shows you the .52 in the routing table.
Details on your subnet below:
http://www.subnet-calculator.com/subnet.php?net_class=A
http://www.subnetonline.com/pages/subnet-calculators/ip-subnet-calculator.php
Inayath
*Plz rate the helpfull posts.
5 Replies 5
InayathUlla Sharieff
Hi Ambivert,
Can you paste the configuration?
I just tested this and it showing me the correct value:
R1---F1/0----------------F1/0 R2
R1
R1#sh run int f1/0
Building configuration...
Current configuration : 98 bytes
interface FastEthernet1/0
ip address 192.168.10.54 255.255.255.0
duplex auto
speed auto
end
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
Gateway of last resort is not set
C    192.168.10.0/24 is directly connected, FastEthernet1/0 <<<<<
#########R2 Config###########
R2#sh run int f1/0
ip address 192.168.10.53 255.255.255.0
duplex auto
speed auto
end
ip route 0.0.0.0 0.0.0.0 192.168.10.54
R2#sh ip route
     Gateway of last resort is 192.168.10.54 to network 0.0.0.0
C    192.168.10.0/24 is directly connected, FastEthernet1/0 <<<<<<<
S*   0.0.0.0/0 [1/0] via 192.168.10.54
Questions:
1- I believe you are not using the default subnet mask on the interface? If i use /30 then I would be seeing the exact route:
R1(config)#int f1/0
R1#show ip route
2- Kinldy provide us the config and we will tell you the reason you are seeing.
Inayath
*Plz rate the usefull posts.
Thanks Inayath I have use this not on default subnet but on subnet of /30 for you reference I am sending you my test
configuration we have like this R1 Fa0/1(10.225.222.54) ------R2 Fa0/1(10.225.222.53) but in #show ip route command it shows "C  10.225.222.52/30 is directly connected ,Fast ethernet 0/1".
So this thing is not clear why it's showing 10.225.222.52  .52 at last please let me know the reason behind it.
Ambivert
it is showing the subnet  and the subnet is .52 , if you had .53 then it would be the host id and it would be a L route on newer 15.x IOS.
Alain
HI Ambivert,
R1(config)#int f1/0
R1#show ip route
In your scenario:
Inayath
ambivert skill
Thanks both of you for explaining me the reason behind it.
Ambivert
