Re: Setting bandwidth on the interface ...
sanjaynadarajah
Level 3
Level 3
My question is :-
1) if we do the below, are we limiting the bandwidth of the interface to the limit put in the bandwidth command?
int s0/0
bandwidth 64
int s0/0.450 point-to-point
bandwidth 32
2) Also how do we check the actual bandwidth of the interface, ie) if it is
a 128K line or a 256k line or etc ?
Thank you,
Cheers,
- sn -
1 for frame-relay you can configure frame-relay traffic shaping and a cir under pvc.
2 to document the circuit and as metric for certain routing protocols.
As an appreciation to those providing answers, please rate posts using the scrollbox below!
paolo bevilacqua
1, no, it is just an informative parameter
2 on some models, show controllers serial x/y. Or you can use ping times to get an idea.
Hi Paolo,
(1) Thanks for the reply. Say I have 3 sub point-to-point interfaces. How do I limit the bandwidth utilization on these 3 interfaces ? by using MQC ? What other ways can I do this task ?
(2) Also if the bandwidth command is informational, what is its purpose for one to use this command in the first place ?
Cheers,
- sn -
