04-06-2013 01:04 AM - edited 03-04-2019 07:30 PM
Hi everybody,
I have the following scenario :
1 Lan / 2 ISP
1) 192.168.0.0/27 will be nat in load-balance (per destination) by 2 interfaces (F0/0,F1/0)
2) Web Server in my LAN (192.168.0.4) will be reach indifferently from 2 ISP (F0/0,F1/0)
For point one .. no problem ..
instead for point two i reach the web server only from one ISP. (for example isp connected to F1/0)
When i try to contact web server from another isp (for example isp connected to F0/0) ..doesn't work ...
If i perform "sh ip nat trans" i see my request from outside ... It seems to me that the router try to answer ever from one default route (default route with the exit int F1/0)
here the config :
interface FastEthernet0/0
description WAN1
ip address 10.0.0.2 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1/0
description WAN3
ip address 10.0.2.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet1/1
description Lan Uffici e Server
ip address 192.168.0.1 255.255.255.192
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 10.0.0.1
ip route 0.0.0.0 0.0.0.0 FastEthernet1/0 10.0.2.1
ip nat inside source route-map WAN1 interface FastEthernet0/0 overload
ip nat inside source route-map WAN3 interface FastEthernet1/0 overload
ip nat inside source static tcp 192.168.0.4 80 10.0.0.2 80 route-map Test1
ip nat inside source static tcp 192.168.0.4 80 10.0.2.2 80 route-map Test2
route-map WAN1 permit 10
match ip address 100
match interface FastEthernet0/0
set ip next-hop 10.0.0.1
route-map WAN3 permit 10
match interface FastEthernet1/0
set ip next-hop 10.0.2.1
route-map Test1 permit 10
match ip address 199
route-map Test2 permit 10
access-list 199 permit tcp host 192.168.0.4 eq 80 any
access-list 100 permit ip 192.168.0.0 0.0.0.63 any
Thanks everybody in advance
04-09-2013 07:49 AM
Try this config because you are using one IP address for NAT and for servers:
no ip nat inside source static tcp 192.168.0.4 80 10.0.0.2 80 route-map Test1
no ip nat inside source static tcp 192.168.0.4 80 10.0.2.2 80 route-map Test2
ip nat inside source static tcp 192.168.0.4 80 interface f0/0 80 extendable
ip nat inside source static tcp 192.168.0.4 80 interface f1/0 80 extendable
Hope it will help.
Best regards,
Abzal
