Recieved BGP route not in routing table
tojo2002
I am having trouble getting a route imported to routing table.
It is a bgp peering between a Cisco ASR and a nokia-unit, similar config works on another ip-net and another peer neighbor.
Looking at received routes from the peer at hand reveals it announces the net but then the cisco wont import it to the routing tables.
Here is output from net not working:
RP/0/RSP0/CPU0:cisco-01#show bgp neighbor 192.168.192.13 received routes
Mon Aug 12 10:11:58.496 CEST
BGP router identifier x.x.x.x, local AS number XXX
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000000   RD version: 890782703
BGP main routing table version 890782703
BGP NSR Initial initsync version 3 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop            Metric LocPrf Weight Path
*  100.73.48.0/22     192.168.192.13                           0 65000 i
Processed 1 prefixes, 1 paths
RP/0/RSP0/CPU0:cisco-01#show route 100.73.48.0
Mon Aug 12 10:25:18.881 CEST
% Network not in table
 Here are the same queries from a net that works:
RP/0/RSP0/CPU0:cisco-01#show bgp neighbor 192.168.15.13 received routes
Mon Aug 12 10:26:54.324 CEST
Table ID: 0xe0000000   RD version: 890795358
BGP main routing table version 890795358
*> 100.73.16.0/22     192.168.15.13                          0 65000 i
RP/0/RSP0/CPU0:cisco-01#show route 100.73.16.0
Mon Aug 12 10:27:04.326 CEST
Routing entry for 100.73.16.0/22
  Known via "bgp XXX", distance 20, metric 0
  Tag 65000, type external
  Installed May 14 11:11:31.022 for 12w5d
  Routing Descriptor Blocks
    192.168.15.13, from 192.168.15.13, BGP external
      Route metric is 0
  No advertising protos.
 Thankful for any help
It was an ACL problem, sloppy mistake from me when copying config from an existing functioning peer.
Thank you for the swift response however!
MHM
you are welcome
MHM
