Recommend a 10gb router
jmcgrady1
What would be your recommended Cisco model to provide 4 x 10gb ethernet routed interfaces?  Support for EIGRP, BGP, and QoS is needed. The less SDWAN functionality the better. Dual PSU is also needed.
https://www.cisco.com/c/en/us/products/routers/router-selector.html
router selector can help you to decide which one is best for your requirement.
balaji.bandi
Are you looking 10GB interface or throughput ?
BB
I'm looking for a minimum 10gb/s throughput (ipv4 routed. No decryption or inspection).
The Cisco NCS540 looks like it does what i need. I understand the NCS range replaces Ciscos Metro Ethernet switch range
Cisco Network Convergence System 540 Medium Density Routers Data Sheet - Cisco
