Recommendation
josue Cabrera
Hi Guys!
What router do you recommend me with dual wan? I reviewing the 1811.
Actually i have two isp?s, one with DSL an other with fiber optic, when one fails, I change the connection to the other manually and reconfigurate for the VPNs (5 VPN)
Please see the attached files.
Thank you for your time!!!
dpopli
Use 1721 with WIC cards
Rate if it helps
depending on the type of connectivity you have with your ISP's, the 1811 (with two 10/100 FE WAN ports) might not be what you are looking for. Have a look at the 1841 instead as well, which is a modular router, with a lot of flexibility with regard to interface cards. Here is the link to the data sheet:
Cisco 1800 Series Integrated Services Routers: Cisco 1841 Router (Modular)
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8016a59b.html
GNT
