Recursive copy command
higgsboson
I have remote router with many scripts on it which need backup. Is there a way to copy more than one file at once from cisco flash , or achive it and then copy? Please help , I have to copy more than hundred files by hand ..
ariela
Level 4
Level 4
you could make this on server side, with a script that you could insert in the crontab for a periodic backup :)
Example for a linux system:
snmpset -t 15 -r 5
..1.3.6.1.4.1.9.2.1.55. s ""
Another option is something like that:
http://www.kiwisyslog.com/kiwi-cattools-overview/
or a netcat tool.
Andrea
Another way to investigate is Embedded Event Manager:
http://blog.ioshints.info/2008/03/copy-file-to-ftp-server-with-eem-applet.html
Andrea
