redirect one ip to an other
ino
equipment
c1111 ipbase
4x lan ports (i think l2 ports ?? you cant create sub interfaces on them cant do no switch port and so on)
2x wan ports can create subintarfaces on them and seems to have a larger comand set then the prvios 4
c2960x ipbase (yes its a l2 switch BUT it hase limited L3 capabilities!!!)
24 ports
what i ultimatly try to acomplis is having multiple servers with the same service running use asl and in case the main one isnt responding redirect to the secondary
an exaple for such a service would be home assitant
HA 1 is 10.0.0.1 VLAN 10
HA 2 is 10.0.0.2 VLAN 10
both are connectred to the 2960x
a desktop from where i need to reach them 20.0.0.1 also connectred to the 2960x VLAN 20
the c1111 is connected to the 2960x with one of his lan ports (trunk port)
interface GigabitEthernet0/1/1
description CON-c1111-c2961
switchport mode trunk
interface Vlan123
description Vlan123
ip address 10.123.0.1 255.255.255.0
ip nat inside
on the 2960x it looks like this
interface GigabitEthernet1/0/1
description C1111
interface Vlan123
ip address 10.123.0.2 255.255.255.0
they are also connected in the folowing way
c1111
interface GigabitEthernet0/0/1
description WAN1 (on this port i can create subintarfaces in contrast to the others)
ip address 10.21.0.1 255.255.255.0
ip nat outside
on the 2960x
interface GigabitEthernet1/0/4
no switchport
ip address 10.21.0.2 255.255.255.0
on the c1111 i have
ip nat inside source static tcp 10.2.12.10 80 10.21.0.1 80 extendable
c1111#sh ip nat t
Pro Inside global Inside local Outside local Outside global
tcp redacted
tcp 10.21.0.1:80 10.2.12.10:80 --- ---
tcp 10.21.0.1:80 10.2.12.10:80 10.2.10.10:50557 10.2.10.10:50557
tcp 10.21.0.1:80 10.2.12.10:80 10.2.10.10:50558 10.2.10.10:50558
tcp 10.21.0.1:80 10.2.12.10:80 10.2.10.10:50556 10.2.10.10:50556
Total number of translations: 5
i assume the problem i am facing in the moment is the back chanel
on 10.2.12.10 i can see requests coming from 10.2.10.10 but on the way back eg. when
10.2.12.10 sends them to 10.2.10.10 they will be routed by the 2960x and the requester
will expect the response from 10.21.0.1 and not from 10.2.12.10
i am a bit lost in the moment any help would be apriciated
6 Replies 6
A bit confuse what you are trying to accomplish. I advise  you to put all this idea in a  simple diagram. That would be easier to anyone  undestand.  Also, if you want to load balance service, you may need a load balancer in between. Another good idea is run this setup in a lab like Packet Tracer, even though you can not test service you can validate connectivity at least.
ino
routing between 10.10.0.0 and 20.0.0.0 is done by the c2960x
so accessing 10.10.0.10 or 10.10.0.20 from 20.0.0.25 will go
desktop --> c2960 --> homeassistant
what i try to acomplis is
10.20.30.1 should bring me to 10.10.0.10 OR 10.10.0.20
depending on if 10.10.0.10 is reachable or not (sla icmp or http probing)
so it should be routed to the second ip just in case the first is unreachable
as a failover (not loadbalancing) this should be done by the c1111
hope this way its a bit more clear what my target is
Much better. But I dont see any 10.20.30.x on your first post.  Can you share the show running-config from both switch and router?
Just to make sure I understood correctly.  From the desktop you will call 10.30.0.1 and you want to pass through the router and reach 10.10.0.x  by using NAT?
ino
no service pad
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
service internal
service sequence-numbers
hostname c2961
boot-start-marker
boot-end-marker
logging buffered 163840
logging persistent url flash:/logs/ size 819200 filesize 16384 batch 8192
enable secret 9 ------------
username --- secret 9 ----------
username --- privilege 15 secret 9 ------------
no aaa new-model
clock timezone --- 1 0
switch 1 provision ws-c2960x-24ts-l
ip routing
no ip cef optimize neighbor resolution
ip dhcp pool 2961-DOMAIN
 network 10.2.10.0 255.255.255.0
 default-router 10.2.10.1
 dns-server 10.10.10.10
 lease 0 0 3
ip domain-name ----.com
ip name-server 10.2.12.10
ip name-server 10.2.12.11
ip accounting-threshold 500
ip accounting-list 0.0.0.0 255.255.255.0
login on-failure log
login on-success log
vtp interface abc
mls qos
crypto pki trustpoint ------
 enrollment mode ra
 enrollment url http://ca.-------.com:80/certsrv/mscep/mscep.dll
 fqdn c2961.------.com
 subject-name CN=c2961.-------.com,O=-----,OU=CORE DEVICE
 subject-alt-name c2961.--------.com
 revocation-check none
 rsakeypair c2961
crypto pki certificate chain -----ROOT
 certificate 6B00000029BB5D07----------
  ---- 665591
  	quit
 certificate ca 57974CA27C57-----------
 ------- D9
  	quit
archive
 path flash:/ConfBack/
 maximum 13
 write-memory
 time-period 1440
spanning-tree mode rapid-pvst
errdisable recovery cause psecure-violation
errdisable recovery interval 30
vlan internal allocation policy ascending
class-map match-all dns-kill
policy-map policy1
 class class-default
  set ip dscp af33
interface FastEthernet0
 description OFF
 no ip address
 no ip route-cache
 shutdown
 description C1111
 switchport port-security maximum 100
 switchport port-security violation restrict
interface GigabitEthernet1/0/2
 description MIKROTIK SXT 2
 switchport access vlan 80
 switchport mode access
interface GigabitEthernet1/0/3
 description apis
 switchport access vlan 20
 switchport port-security maximum 9
 spanning-tree portfast edge
 service-policy input policy1
 no switchport
interface GigabitEthernet1/0/5
 description E1-1
 switchport trunk allowed vlan 20
interface GigabitEthernet1/0/6
 description E1-2
interface GigabitEthernet1/0/7
 description OFF
interface GigabitEthernet1/0/8
 description OFF
 no switchport
 no ip address
interface GigabitEthernet1/0/9
 description E2-1
interface GigabitEthernet1/0/10
 description Apep 2
interface GigabitEthernet1/0/11
 description OFF
interface GigabitEthernet1/0/12
 description HSwitch
 switchport access vlan 7
 switchport trunk allowed vlan 7,1920-1930
 switchport trunk native vlan 7
 switchport port-security maximum 15
interface GigabitEthernet1/0/13
 description HSwitch
 switchport access vlan 50
 switchport trunk native vlan 50
interface GigabitEthernet1/0/14
 description POE Switch
 switchport access vlan 255
interface GigabitEthernet1/0/15
 description OFF
interface GigabitEthernet1/0/16
 description OFF
interface GigabitEthernet1/0/17
 description OFF
interface GigabitEthernet1/0/18
 description OFF
interface GigabitEthernet1/0/19
 description OFF
interface GigabitEthernet1/0/20
 description laptop
interface GigabitEthernet1/0/21
 description Nic 1/3 domain, adg
 switchport port-security maximum 50
 switchport port-security violation shutdown vlan
interface GigabitEthernet1/0/22
 description Nic 1/2 wlc
interface GigabitEthernet1/0/23
 description Nic 1/3 vision
interface GigabitEthernet1/0/24
 description Ra Nic 1/4 grafana, prometheus, influx, sql, scraperw
 switchport access vlan 12
interface GigabitEthernet1/0/25
 description OFF
 shutdown
interface GigabitEthernet1/0/26
 description OFF
 shutdown
interface GigabitEthernet1/0/27
 description OFF
 shutdown
interface GigabitEthernet1/0/28
 description OFF
 shutdown
interface Vlan1
 description OFF
 no ip address
interface Vlan5
 ip address 10.250.250.1 255.255.255.0
interface Vlan7
 ip address 10.0.0.2 255.255.255.0
interface Vlan20
 description 2961-MAIN
 ip address 10.2.0.1 255.255.255.0
interface Vlan50
 ip address 10.5.0.10 255.255.255.0
 ip helper-address 10.0.0.1
interface Vlan60
 ip address 10.6.0.10 255.255.255.0
interface Vlan80
 ip address 10.8.0.10 255.255.255.0
interface Vlan90
 ip address 10.9.0.10 255.255.255.0
interface Vlan210
 description 2961-DOMAIN
 ip address 10.2.10.1 255.255.255.0
interface Vlan212
 description 2961-DNS
 ip address 10.2.12.1 255.255.255.0
interface Vlan220
 ip address 10.2.20.1 255.255.255.0
interface Vlan230
 description 2961-OPENHAB
 ip address 10.2.30.1 255.255.255.0
interface Vlan250
 description 2961-VISION
 ip address 10.2.50.1 255.255.255.0
interface Vlan255
 ip address 10.2.55.1 255.255.255.0
interface Vlan290
 ip address 10.2.90.1 255.255.255.0
interface Vlan1505
 description WLAN-------
 ip address 192.168.5.1 255.255.255.0
interface Vlan1510
 description WLAN-B
 ip address 192.168.10.1 255.255.255.0
interface Vlan1520
 description WLAN-S
 ip address 192.168.20.1 255.255.255.0
interface Vlan1530
 description WLAN-W
 ip address 192.168.30.1 255.255.255.0
interface Vlan1540
 description WLAN-WC
 ip address 192.168.40.1 255.255.255.0
interface Vlan1920
 description Vlan1920
 ip address 192.168.0.1 255.255.255.0
interface Vlan1921
 description Vlan1921
router ospf 1
 router-id 10.2.0.1
 redistribute connected subnets
 redistribute static subnets
 network 10.0.0.0 0.0.0.255 area 0
 network 10.2.0.0 0.0.255.255 area 0
 network 10.5.0.0 0.0.255.255 area 0
 network 10.6.0.0 0.0.255.255 area 0
 network 10.8.0.0 0.0.255.255 area 0
 network 10.9.0.0 0.0.255.255 area 0
 network 192.168.0.0 0.0.255.255 area 0
ip default-gateway 10.0.0.1
no ip ftp passive
ip ftp username c2961
ip ftp password 7 -----------
no ip http server
ip http banner
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip ssh client algorithm encryption aes128-cbc aes128-ctr aes192-cbc aes192-ctr aes256-cbc aes256-ctr
ip access-list standard LogIn
ip access-list extended LTE-M-1
 permit ip host 10.0.0.66 any
ip access-list extended TEST
 permit ip any host 10.0.10.10
ip access-list extended dns-block
 deny   tcp any any eq domain
 deny   udp any any eq domain
 permit ip any any
ip access-list extended test
 permit ip host 10.2.12.10 any
logging source-interface Vlan20
logging host 10.9.0.1
route-map test permit 5
 match ip address test
 set ip next-hop 10.21.0.1
route-map test permit 10
 set ip next-hop 10.0.0.8
route-map LTE-MAP permit 5
 match ip address LTE-M-1
 set ip next-hop 10.0.0.9
snmp-server group grp1 v3 priv read ViewDefault
snmp-server view ViewDefault iso included
snmp mib flash cache
banner login authorized users only, violaters will be remote electrocuted!!!
banner motd authorized users only, violaters will be shot on sight!
alias exec xwr copy run ftp://10.0.0.6/c2960x/
line con 0
 exec-timeout 30 0
 logging synchronous
 login
 length 50
 stopbits 1
line vty 0 4
 access-class LogIn in
 exec-timeout 30 0
 logging synchronous
 login local
 length 50
 transport input ssh
line vty 5 15
 login
 transport input ssh
monitor session 1 source vlan 1621 , 1624
monitor session 1 destination interface Gi1/0/28
ntp server 10.1.1.1
event manager environment _email_to ----------
event manager environment _email_from admin@-----.com
event manager environment _email_server apikey:-------
event manager applet ssh-login
 event syslog pattern "SEC_LOGIN.*"
 action 1.0 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "$_event_pub_time: c2960x Login via SSH" body "$_syslog_msg"
 action 1.5 syslog priority notifications msg "SSH LOGIN - Mail Sent"
end
ino
version 16.9
no service pad
service internal
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 150000
hostname c1111
boot-start-marker
boot system flash bootflash:c1100-universalk9_ias.16.09.06.SPA.bin
boot-end-marker
logging persistent url bootflash:/logs/ size 819200 filesize 16384 batch 8192
aaa new-model
aaa authorization network IKEv2_GROUP_AUTHZ local
aaa session-id common
clock timezone ---- 1 0
ip name-server 10.2.12.10 10.2.12.11
ip domain name -----.com
ip ddns update method control
 HTTP
  add http:----------
 interval maximum 0 0 5 0
ip ddns update method -----com
 HTTP
  add http:----------
ip dhcp subscriber-id interface-name
ip dhcp excluded-address 192.168.0.1 192.168.0.80
subscriber templating
crypto pki server VPN_CA
 no database archive
 grant auto
 eku server-auth client-auth
crypto pki trustpoint VPN_CA
 revocation-check crl
 rsakeypair VPN_CA
crypto pki trustpoint VPNSERVERCERT
 enrollment url http://10.0.0.1:80
 subject-name CN=-----------.buzz
 rsakeypair VPNSERVERCERT
crypto pki trustpoint -----ROOT
 enrollment mode ra
 enrollment url http://ca.----.com:80/certsrv/mscep/mscep.dll
 fqdn c1111.-----.com
 subject-name CN=c1111.----.com,O=------,OU=CORE DEVICE
 subject-alt-name c1111.-----.com
 rsakeypair c1111
crypto pki certificate map CERT_MAP 10
 name co -----
 issuer-name co -----
crypto pki certificate chain VPN_CA
 certificate ca 01
------ 8FDF3C09
  	quit
crypto pki certificate chain VPNSERVERCERT
 certificate 02
------ E74DCF78
  	quit
 certificate ca 01
 ------8FDF3C09
  	quit
 certificate ca 57974CA27C5------
  ------ D9
  	quit
archive
 maximum 13
 write-memory
 time-period 1440
diagnostic bootup level complete
mac address-table aging-time 0
username --- secret 9 -------------
redundancy
 mode none
crypto ikev2 authorization policy IKEv2_AUTHZ_POLICY
 pool VPNPOOL
 dns 10.2.12.10 10.2.12.11
 netmask 255.255.255.0
 def-domain -------
 route set access-list split_tunel
crypto ikev2 proposal default
 encryption aes-cbc-256 aes-cbc-192 aes-cbc-128
 integrity sha512 sha384 sha256
 group 21 20 14 19
crypto ikev2 policy default
 match fvrf any
 proposal default
crypto ikev2 profile IKEv2_PROFILE
 match certificate CERT_MAP
 authentication remote rsa-sig
 authentication local rsa-sig
 pki trustpoint ------ROOT
 aaa authorization group cert list IKEv2_GROUP_AUTHZ IKEv2_AUTHZ_POLICY
 virtual-template 1
 reconnect timeout 900
no crypto ikev2 http-url cert
controller Cellular 0/2/0
 no lte gps enable
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
track 1 ip sla 1 reachability
class-map match-all LTE_Priority_Traffic
 match access-group 101
class-map match-all test_match
policy-map LTE_Child
 class LTE_Priority_Traffic
  priority 10240
 class class-default
  fair-queue
policy-map LTE-Yettel-Primery
 class class-default
  fair-queue
  fair-queue queue-limit 5
policy-map LTE_Parent
 class class-default
  shape average 10240000
   service-policy LTE_Child
policy-map test_mark
 class test_match
  set ip dscp 1
crypto logging session
crypto logging ezvpn
crypto logging ikev2
crypto ipsec profile IPSEC_PROFILE
 set ikev2-profile IKEv2_PROFILE
interface Loopback0
 description NTP
 ip address 10.1.1.1 255.255.255.255
 ntp broadcast
interface Loopback1
 description VPN
 ip address 172.16.0.1 255.255.255.255
interface GigabitEthernet0/0/0
 description WAN0
 ip ddns update -----com
 ip address dhcp
 ip access-group VPN in
 negotiation auto
 no ip redirects
 ip nat outside
 negotiation auto
interface GigabitEthernet0/1/0
 description -----
interface GigabitEthernet0/1/2
 description -----
 switchport port-security maximum 25
interface GigabitEthernet0/1/3
 description SXT01
 switchport access vlan 70
interface Cellular0/2/0
 description LTE
 ip ddns update control
 ip address negotiated
 ip nat outside
 load-interval 30
 history BPS all
 dialer in-band
 dialer watch-group 1
 pulse-time 1
 ip virtual-reassembly
 ip virtual-reassembly-out
interface Cellular0/2/1
 description LTE 2
 no ip address
interface Virtual-Template1 type tunnel
 description Cisco AnyConnect IKEv2
 ip unnumbered Loopback1
 ip mtu 1400
 ip tcp adjust-mss 1360
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile IPSEC_PROFILE
interface Vlan1
 description OFF
 no ip address
 ip nat inside
interface Vlan7
 description Vlan7
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 ip policy route-map LTE-MAP
interface Vlan11
 ip address 10.0.1.2 255.255.255.0
 ip nat inside
interface Vlan70
 ip address 10.7.0.10 255.255.255.0
 ip nat inside
interface Vlan80
 ip address 10.8.0.254 255.255.255.0
 ip nat inside
interface Vlan123
 ip nat outside
interface Vlan666
 no ip address
router ospf 1
 router-id 10.0.0.1
 network 10.0.0.0 0.0.0.0 area 0
 network 10.0.1.2 0.0.0.0 area 0
 network 10.0.1.0 0.0.0.255 area 0
 network 10.0.0.0 0.0.255.255 area 0
 network 10.1.1.1 0.0.0.0 area 0
 network 10.7.0.10 0.0.0.0 area 0
 network 10.7.0.0 0.0.0.255 area 0
 network 10.99.2.1 0.0.0.0 area 0
 network 10.99.99.1 0.0.0.0 area 0
ip local policy route-map router_local
ip local pool VPNPOOL 172.16.0.101 172.16.0.103
ip forward-protocol nd
no ip ftp passive
ip ftp username -----
no ip http server
ip dns server
ip nat translation timeout 300
ip nat translation tcp-timeout 300
ip nat translation udp-timeout 300
ip nat translation finrst-timeout 60
ip nat translation syn-timeout 60
ip nat translation dns-timeout 60
ip nat translation icmp-timeout 60
ip nat inside source static tcp 172.16.200.200 2222 interface Cellular0/2/0 22
ip nat outside source static 10.2.12.10 10.21.0.10 add-route
ip nat outside source static 10.2.12.15 10.21.0.20 add-route
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
ip ssh version 2
ip access-list standard split_tunel
 permit 10.0.0.0 0.255.255.255
 permit 172.16.0.0 0.0.255.255
 permit 192.168.0.0 0.0.255.255
 permit ip 192.168.5.0 0.0.0.255 any
 deny   ip 10.12.34.0 0.0.0.255 any
 deny   ip host 10.2.0.10 any
 deny   ip host 10.2.0.20 any
 deny   ip host 10.2.0.100 any
 deny   ip any 192.168.0.0 0.0.255.255
 deny   ip any 172.16.0.0 0.15.255.255
 deny   ip any 10.0.0.0 0.255.255.255
 permit ip 10.0.0.0 0.255.255.255 any
ip access-list extended LTE-M-2
 permit ip host 10.2.90.10 any
ip access-list extended NAT-L
 deny   ip any any
ip access-list extended VPN
 permit object-group PORT_VPN any any log-input
 permit ip any any
ip access-list extended router_local
 permit ip host 10.7.0.10 host 1.1.1.1
ip sla 1
 icmp-echo 1.1.1.1 source-interface Vlan70
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 10.2.0.1
ip sla schedule 2 life forever start-time now
ip sla 7
 icmp-echo 10.7.0.1
ip sla schedule 7 life forever start-time now
ip sla 8
 icmp-echo 10.8.0.1
ip sla schedule 8 life forever start-time now
logging source-interface Vlan7
dialer watch-list 1 ip 8.8.8.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
dialer-list 1 protocol ip permit
menu Base text 1. .LTE Radio.
menu Base command 1. show cellular 0/2/0 radio
menu Base options 1. pause
menu Base text 2. .View SMS.
menu Base command 2. cellular 0/2/0 lte sms view summary
menu Base options 2. pause
menu Base text 3. .Interface Brief.
menu Base command 3. show ip interface brief
menu Base options 3. pause
menu Base text 4. .DHCP Bindings.
menu Base command 4. show ip dhcp binding
menu Base options 4. pause
menu Base text 5. .Show Run.
menu Base command 5. show run
menu Base options 5. pause
menu Base text 6. .ping.
menu Base command 6. ping 8.8.8.8
menu Base options 6. pause
menu Base text 7. .pingggg.
menu Base command 7. ping 8.8.8.8 rep 250
menu Base options 7. pause
menu Base text 8. policy
menu Base command 8. sh policy-map interface
menu Base options 8. pause
menu Base text 9. lte RESET
menu Base command 9. test cellu 0/2/0 modem-power-cycle
menu Base options 9. pause
menu Base text q .End Menu.
menu Base command q menu-exit
menu Base default q
route-map LTE-MAP permit 1
 match ip address LTE-M-2
 set ip next-hop 10.8.0.1
 set ip next-hop 10.7.0.1
route-map router_local permit 10
 match ip address router_local
control-plane
alias exec xsms cellular 0/2/0 lte sms view summary
alias exec x menu Base
alias exec xib show ip interface brief
alias exec xr show cellular 0/2/0 radio
alias exec xd show ip dhcp binding
alias exec xwr copy run ftp://10.0.0.6/c1111/
default-value special-character-bits 8
line con 0
 exec-timeout 30 0
 logging synchronous
 length 50
 width 250
 transport input none
 stopbits 1
line vty 0 4
 exec-timeout 30 0
 length 50
 width 250
 transport input ssh
line vty 5 20
 exec-timeout 30 0
 length 50
 width 250
 transport input ssh
ntp master
ntp server 0.europe.pool.ntp.org
end
ino
this is the ip i want to redirect or some other from this subnet
 no ip redirects
 ip nat outside
 negotiation auto
and here it connects to the 2960
 no switchport
this is just testing i tryed whit inside / outside swaping the ips ....
the ip to wich i want to redirect is connected to the 2960
chuse any you like
