Redist Static Routes via EIGRP
GRANT3779
Hi All,
I have a router that has a load of static routes. I want to redistribute these routes to another router running EIGRP on the same ethernet segment. I setup an access list etc permitting the routes and the associated route-map. I also know the commanto redist within EIGRP.
However, I only want to advertise / send these static routes, no other. Do I still need to apply the network command under the EIGRP process? Basically I don't want to advertise the network the interface is on, if that makes sense?
I might be overthinking this, but all I want to do is have EIGRP running on my router and only have it redistributes my static addresses.
John Blakley
You have to have a neighborship between the two routers which means that you'll be advertising that network. If your acl matches only the static routes that you want to advertise, appying that with a route map will keep from advertising anything further. You do not need to advertise the statics with the network command, but the network command obviously has to match on whatever interface the neighbor is on and should be receiving routes.
int fa0/0 <--- your neighbor will be off of this interface
ip address 192.168.15.1 255.255.255.0
ip route 192.168.1.0 255.255.255.0 192.168.15.10
access-list 1 permit 192.168.1.0 0.0.0.255
route-map Only192 permit
match ip address 1
router eigrp 100
no auto
network 192.168.15.1 0.0.0.0
redistribute static metric 1 1 1 1 1 route-map Only192
Am I understanding the question?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
7 Replies 7
John Blakley
match ip address 1
router eigrp 100
no auto
HTH,
John
Hi John,
Thanks, yeah you understood what I was putting across. So in your example, the command
Will this advertise the network 192.168.15.0 /24 to my EIGRP neighbour? As this is what I don't want to happen. Or does that command just allow me to form the neighbour relationship?
Hmm...technically the two networks are connected, so your neighbor would see the same route as you as connected and nothing more. They have to be on the same subnet in order to form an adjacency. Then the neighbor will see the statics that you're advertising, but the next hop will show this router's interface.
HTH,
John
That makes complete sense....I wasover thinking it! Thanks very much John.
You're welcome!
HTH,
John
Hi John,
Just a quick one. If my router interface on that LAN segment is for example 172.25.10.10 255.255.252.0, should my network statement under EIGRP process just be the actual interface address and not the network address.
e.g
network 172.25.10.10 0.0.0.0
Also, if I have OSPF running on the same router, will the EIGRP have any affect on this or can they run side by side?
Cheers
I'd recommend only specifying the interface address alone like your example. You can run both protocols simultaneously and they won't have any impact UNLESS you are learning the same subnet from both protocols, in which case the eigrp route would be preferred.
HTH,
John
