Redistribute EIGRP into BGP with backup routes
Bill19795_2
Here is the scenario. I have two routers, each router has a single WAN link but to two different providers. RouterA is connected to ProviderA and RouterB is connected to PrivderB. The providers are using BGP for their routing. I am exchanging routers to them using BGP.  In RouterA I have a loopback adaptor for H.323 traffic that I need to distribute to both providers. Also I need to make sure that both routers see the head end IP subnet of 192.168.200.x. I am running EIGRP internally and BGP into the provider. I have successfully configured redistribution between BGP and EIGRP. Everything works fine on the redistribution except when a WAN link fails. When one of the circuits fails it causes me to loose connectivity to the head end router, I then loose my BGP routes from that link. It then immediately installs the EIGRP routes learned from the other router into my routing table and all connectivity remains intact. The problem is when the Serial link is back and the BGP routes a learned they do not remove the EIGRP routes and the serial link is not used because the router things it should send traffic over EIGRP to the other router. If I reset the EIGRP neighbors then the BGP route is reinserted. The BGP as an AD of 20 and the EIGRP has AD of 170 so I don’t understand why it is not removing the EIGRP route once BGP comes back online.
Hello Bill,
int this case you want to prefer the EIGRP route over the BGP route for specific IP subnets.
I will assume that the IP subnets of interest are those of the loopbacks:
192.168.200.x  on router Ry
this effect can be achieved by using the network backdoor command in router bgp configuration
R1:
router bgp 65001
network 192.168.200.3 mask 255.255.255.255 backdoor
R2:
router bgp 65001
network 192.168.200.2 mask 255.255.255.255 backdoor
the result is that eBGP route for 192.168.200.x on Ry is presented on IP routing table with AD 200 and EIGRP route will be installed for its lower Administrative distance (170 worst case if D EX)
see
http://www.cisco.com/en/US/docs/ios/iproute_bgp/configuration/guide/irg_basic_net_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1056114
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello Bill,
The issue is created in the BGP table: a locally injected BGP route into the BGP table as a result of redistribution of EIGRP into BGP has weight 32,768 by default and when the original eBGP route is restored is not able to be considered the BGP best path for its lower weight.
AD plays no role in BGP table. An AD is attached to the route that BGP choices as best path by the IP routing table maintainer process.
The solution I used to solve the problem of eBGP restore is to give a weight of 40,000 > 32,768 to eBGP routes coming from eBGP neighbor.
In this way when the eBGP session is restored its routes are again chosen as best paths  and reinstalled in the BGP table and then in the IP routing table.
Hope to help
Giuseppe
Do you think you can help me out with the configuration? This is from RouterA
Ignore the allowas-in command. This is in my lab and I have it connected to a simulated PSTN router.
router eigrp 50
redistribute bgp 65001
network 10.1.2.0 0.0.0.255
network 192.168.2.0
network 192.168.200.2 0.0.0.0
default-metric 1000 100 250 100 1500
no auto-summary
router bgp 65001
no synchronization
bgp log-neighbor-changes
redistribute eigrp 50
neighbor 172.16.200.9 remote-as 2020
neighbor 172.16.200.9 allowas-in 1
no auto-summary
Hello Bill,
given the configuration template that you have provided I suggest the following change:
router bgp 65001
neigh 172.16.200.9 weight 40000
the reasons are explained in my previous post on this thread
Hope  to help
Giuseppe
Thanks for all your help so far. While adjusting the weight does work I now have other problems.
Each Router has a loopback adaptor that needs to be seen be each other router locally and throughout the BGP network. When I use the weight commands the BGP routes are reinserted but it is also using BGP to route traffic for the loopback adaptors. These are both connected via the same Ethernet network so I want them to stay local instead of going through the MPLS network. Also if I shut down the S0/0 from R2 it will start using the BGP routes but R1 does not use EIGRP and keeps using the BGP routes so it is trying to send traffic over the MPLS when it should send it locally.
R1:
interface Loopback10
ip address 192.168.200.3 255.255.255.255
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.2.13 255.255.255.0
glbp 1 ip 10.1.2.10
glbp 1 timers 1 3
glbp 1 timers redirect 2 14400
glbp 1 priority 105
glbp 1 preempt
glbp 1 weighting 110 lower 95 upper 105
glbp 1 weighting track 1 decrement 20
glbp 1 forwarder preempt delay minimum 2
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.2.13 255.255.255.0
glbp 2 ip 192.168.2.10
glbp 2 timers 1 3
glbp 2 timers redirect 2 14400
glbp 2 priority 105
glbp 2 preempt
glbp 2 weighting 110 lower 95 upper 105
glbp 2 weighting track 1 decrement 20
glbp 2 forwarder preempt delay minimum 2
interface Serial0/0
ip address 172.16.200.14 255.255.255.252
service-module t1 timeslots 1-24
router eigrp 50
network 192.168.2.0
network 192.168.200.3 0.0.0.0
no auto-summary
router bgp 65001
no synchronization
neighbor 172.16.200.13 remote-as 2020
neighbor 172.16.200.13 allowas-in 1
neighbor 172.16.200.13 weight 40000
no auto-summary
LAP_B1R2#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
D EX    1.1.1.10 [170/2588160] via 192.168.2.12, 00:13:27, FastEthernet0/0.2
                 [170/2588160] via 10.1.2.12, 00:13:27, FastEthernet0/0.1
     2.0.0.0/32 is subnetted, 1 subnets
B       2.2.2.10 [20/0] via 172.16.200.13, 00:04:17
     172.16.0.0/30 is subnetted, 1 subnets
C       172.16.200.12 is directly connected, Serial0/0
     192.168.200.0/32 is subnetted, 3 subnets
B       192.168.200.1 [20/0] via 172.16.200.13, 00:04:17
B       192.168.200.2 [20/0] via 172.16.200.13, 00:04:18
C       192.168.200.3 is directly connected, Loopback10
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.2.0 is directly connected, FastEthernet0/0.1
C    192.168.2.0/24 is directly connected, FastEthernet0/0.2
LAP_B1R2#
R2:
no ip address
speed auto
glbp 1 ip 10.1.2.10
glbp 1 timers 1 3
glbp 1 priority 105
glbp 1 preempt
glbp 2 timers 1 3
glbp 2 priority 105
glbp 2 preempt
interface Serial0/0
router eigrp 50
network 192.168.2.0
no auto-summary
router bgp 65001
no synchronization
no auto-summary
D EX    1.1.1.10 [170/2588160] via 192.168.2.12, 00:15:24, FastEthernet0/0.2
                 [170/2588160] via 10.1.2.12, 00:15:24, FastEthernet0/0.1
B       2.2.2.10 [20/0] via 172.16.200.13, 00:06:14
B       192.168.200.1 [20/0] via 172.16.200.13, 00:06:14
B       192.168.200.2 [20/0] via 172.16.200.13, 00:06:15
LAP_B1R2#
Shutdown S0/0 on R2:
LAB_B1R2(config)#int s0/0
LAB_B1R2(config-if)#sh
LAB_B1R2(config-if)#shutdown
LAB_B1R2(config-if)#e
*Mar  5 03:19:28.631: %TRACKING-5-STATE: 1 interface Se0/0 line-protocol Up->Down
*Mar  5 03:19:28.635: %BGP-5-ADJCHANGE: neighbor 172.16.200.13 Down Interface flapnd
LAB_B1R2#
LAB_B1R2#
LAB_B1R2#
*Mar  5 03:19:30.426: %SYS-5-CONFIG_I: Configured from console by console
*Mar  5 03:19:30.626: %LINK-5-CHANGED: Interface Serial0/0, changed state to administratively down
*Mar  5 03:19:30.803: %GLBP-6-FWDSTATECHANGE: FastEthernet0/0.1 Grp 1 Fwd 2 state Active -> Listen
*Mar 5 03:19:30.803: %GLBP-6-FWDSTATECHANGE: FastEthernet0/0.2 Grp 2 Fwd 2 state Active -> Listen
*Mar  5 03:19:31.628: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to down
LAB_B1R2#show ip route
D EX    1.1.1.10 [170/2588160] via 192.168.2.12, 00:16:16, FastEthernet0/0.2
                 [170/2588160] via 10.1.2.12, 00:16:16, FastEthernet0/0.1
D EX    192.168.200.1
           [170/2588160] via 192.168.2.12, 00:00:17, FastEthernet0/0.2
           [170/2588160] via 10.1.2.12, 00:00:17, FastEthernet0/0.1
D       192.168.200.2
           [90/156160] via 192.168.2.12, 00:00:17, FastEthernet0/0.2
           [90/156160] via 10.1.2.12, 00:00:18, FastEthernet0/0.1
LAB_B1R2#
LAB_B1R2#
R1:
LAB_B1R1#show ip route
B       1.1.1.10 [20/0] via 172.16.200.9, 00:17:20
C       172.16.200.8 is directly connected, Serial0/0
B       192.168.200.1 [20/0] via 172.16.200.9, 00:17:20
C       192.168.200.2 is directly connected, Loopback10
D       192.168.200.3
           [90/156160] via 192.168.2.13, 00:00:05, FastEthernet0/0.2
           [90/156160] via 10.1.2.13, 00:00:05, FastEthernet0/0.1
LAB_B1R1#
Hello Bill,
R1:
router bgp 65001
R2:
router bgp 65001
see
Hope to help
Giuseppe
Thanks for the help. I ended up using the weighting that you said plus using a route map to only distribute the routes into BGP that I needed.
Everything is working as desired.
