Redistribute only learned routes from BGP to EIGRP
Rick_Dees
What might seem quite a simple config, but can’t seem to find a clear answer
I have ebgp running in a closed environment,
I am advertising a aggregate summary address out via bgp ie,
router bgp 65001
bgp log-neighbors
aggregate-address 100.0.0.0 255.0.0.0
Then I am doing a redistribution into eigrp
router eigrp 1
network 100.0.0.0 255.255.0.0
network 100.1.0.0 255.255.0.0
redistribute bgp 65001 metric 100 1 255 1 1500
this however will redistribute the aggregate address back into eigrp..which is causing issues..
what’s the best way to only redistribute routes that are learned from the connected bgp peers?
TIA
Harold Ritter
Hi @Rick_Dees ,
You can use a route-map when redistributing into EIGRP to specifically exclude the aggregate address.
router eigrp 1
redistribute bgp 1 metric 100 1 255 1 1500 route-map deny-aggregate
ip prefix-list aggregate seq 5 permit 100.0.0.0/8
route-map deny-aggregate deny 10
match ip address prefix-list aggregate
route-map deny-aggregate permit 20
or specifically exclude the locally generated  BGP routes:
route-map deny-local deny 10
match route-type local
route-map deny-local permit 20
