05-07-2011 05:58 PM - edited 03-04-2019 12:18 PM
hi, thanks first,
R2---OSPF----R1---BGP---R3
It is a simple topology. R1 is the border router for both BGP and OSPF. It redistributes both into each other.
R3 can show R2's loop interface, which indicates everything is fine with redistributing OSPF into BGP.
But R2 cannot see any loop interface on R3. When i do show ip ospf database on the R1, it doesnt have any routes to R3 in the database.
By the way, R1 can reach R3's loop interfaces from BGP. any idea?
Here is the configs,
=====R1=====
interface Loopback0
ip address 172.16.101.1 255.255.255.0
interface Serial0/0
ip address 10.1.12.2 255.255.255.0
serial restart-delay 0
interface Serial0/1
ip address 10.1.13.1 255.255.255.0
router ospf 1
log-adjacency-changes
redistribute bgp 100 subnets
network 10.1.12.2 0.0.0.0 area 0
network 172.16.101.1 0.0.0.0 area 0
no summary
router bgp 100
no synchronization
bgp log-neighbor-changes
network 10.1.13.0 mask 255.255.255.0
redistribute ospf 1
neighbor 10.1.13.3 remote-as 100
no auto-summary
======R2======
interface Loopback0
ip address 172.16.102.2 255.255.255.0
interface Serial0/0
ip address 10.1.12.1 255.255.255.0
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
=====R3========
interface Loopback0
ip address 172.16.103.3 255.255.255.0
interface Loopback1
ip address 3.3.3.3 255.255.255.255
interface Serial0/0
ip address 10.1.13.3 255.255.255.0
router bgp 100
no synchronization
network 3.3.3.3 mask 255.255.255.255
network 172.16.103.0 mask 255.255.255.0
neighbor 10.1.13.1 remote-as 100
no auto-summary
=======Show ip ospf database from R1====
R1#sh ip os da
OSPF Router with ID (172.16.101.1) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
172.16.101.1 172.16.101.1 5 0x8000000F 0x0023E1 3
172.16.102.2 172.16.102.2 1508 0x80000004 0x00F3DA 3
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
10.1.13.0 172.16.101.1 5 0x80000002 0x00AACC 0
R1#
==========show ip route from R2=========
R2#
*Mar 1 01:15:15.587: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.101.1 on Serial0/0 from LOADING to FULL, Loading Done
R2#sh ip route
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
O 172.16.101.1/32 [110/65] via 10.1.12.2, 00:00:50, Serial0/0
C 172.16.102.0/24 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 2 subnets
O E2 10.1.13.0 [110/1] via 10.1.12.2, 00:00:50, Serial0/0
C 10.1.12.0 is directly connected, Serial0/0
R2#
Solved! Go to Solution.
05-08-2011 11:32 AM
Han,
Good question! 5-Point for you. R3 is advertising routes via iBGP. If you enabled a synchronization on R1, those routes won't be installed in RIB on R1. You can check "sh ip bgp and sh ip route". Because those routes have not been in IGP(it's a rule). In short if those routes have not been installed on the routing table the router can't redistribute them as well. That's why you didn't see anything on R2.
HTH,
Toshi
05-07-2011 06:55 PM
Since you are running IBGP between r1 and r3, you need to use the loopback interface of each router as neighbors. But before you do that, you need to have reachability between the 2 loopbacks interfaces..
so try this "sh ip bg sum"
do you see the peering between r1 and r3 established?
from r1 can you ping the loopback address of r3 router?
from r3 can you ping the loopback address of r1 router?
05-07-2011 08:13 PM
reza,
Why is it that it needs the loop interface for the neighbors?
I also managed to make it can ping the loop interfaces between R1 and R3. However, the BGP always stuck in Active mode.
any idea?
thanks,
Han
05-07-2011 08:31 PM
Usually when using IBGP, you use the loopback adress. The reason for it is that the loopback address is a logical interface and it never goes down. If you use a physical interface in a redundant environment and if that interface goes down you loose you BGP peering but with loopback you will not
If you can ping from r1 to r3 loopback and r3 to r1 loopback try below config
=====R1=====
interface Loopback0
router bgp 100
neighbor 172.16.103.3 remote-as 100
neighbor 172.16.103.3 update-source Loopback0
no auto-summary
=====R3========
interface Loopback0
router bgp 100
neighbor 172.16.101.1 remote-as 100
neighbor 172.16.101.1 update-source Loopback0
no auto-summary
05-07-2011 09:17 PM
yes, i did change as to use the loopback interface. The R2 still has no route from R3.
05-08-2011 01:00 AM
Your original configuration looks good to me. Keep in mind, by default iBGP redistribution into IGP is disabled. If you want to do,just add a "bgp redistribute-internal" command on R1. You will finally see what you want. It's disabled because it can cause routing loop within AS.
HTH,
Toshi
05-08-2011 09:43 AM
thot,
I tried with the command address-family ipv4 and bgp redistribute-internal. But it is still the same. No routes from R3 found in R2's OSPF database.
R2#sh ip os da
OSPF Router with ID (172.16.102.2) (Process ID 1)
172.16.101.1 172.16.101.1 95 0x8000000A 0x004287 3
172.16.102.2 172.16.102.2 1785 0x80000008 0x00EBDE 3
10.1.13.0 172.16.101.1 94 0x80000003 0x00A8CD 0
R2#
05-08-2011 09:54 AM
I didn't see "address-family ipv4" in your original post. Do you need to use it?
R1:
router bgp 100
HTH,
Toshi
05-08-2011 10:18 AM
I used it after saw you post, here is config from R1 and show output fromR2.
R1(config)#do sh run | b r o
router ospf 1
router bgp 100
bgp router-id 172.16.101.1
address-family ipv4
redistribute ospf 1
neighbor 172.16.103.3 activate
no auto-summary
no synchronization
exit-address-family
R2#sh ip os da
172.16.101.1 172.16.101.1 251 0x8000000B 0x004088 3
172.16.102.2 172.16.102.2 1998 0x80000009 0x00E9DF 3
10.1.13.0 172.16.101.1 251 0x80000004 0x00A6CE 0
R2#
05-08-2011 10:27 AM
Hi Guys,
Your original configuration is fine to me. Just add a command I told you. In your new configuration you need to do more things. If you want to use a loopback as a source of iBGP you have to know how to route it to the destination. Please post the output of "show ip bgp sum & sh ip bgp" on R1.
HTH,
Toshi
05-08-2011 10:34 AM
now, i use the serial interfaces in the neighbor command. It is still the same in R2. show config and others from R1 is pasted, thanks,
R1(config-router-af)#do sh run | b r b
router bgp 100
address-family ipv4
redistribute ospf 1
neighbor 10.1.13.3 activate
no auto-summary
synchronization
exit-address-family
no ip http server
no ip http secure-server
ip classless
ip route 172.16.103.3 255.255.255.255 10.1.13.3
R1(config-router-af)#do sh ip bg summ
BGP router identifier 172.16.101.1, local AS number 100
BGP table version is 47, main routing table version 47
6 network entries using 606 bytes of memory
7 path entries using 336 bytes of memory
4 BGP path attribute entries using 240 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 1182 total bytes of memory
BGP activity 15/9 prefixes, 27/20 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.1.13.3 4 100 7 11 47 0 0 00:02:49 3
BGP table version is 47, local router ID is 172.16.101.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* i3.3.3.3/32 10.1.13.3 0 100 0 i
*> 10.1.12.0/24 0.0.0.0 0 32768 ?
* i10.1.13.0/24 10.1.13.3 0 100 0 i
*> 0.0.0.0 0 32768 i
*> 172.16.101.0/24 0.0.0.0 0 32768 ?
*> 172.16.102.2/32 10.1.12.1 65 32768 ?
* i172.16.103.0/24 10.1.13.3 0 100 0 i
R1(config-router-af)#do sh ip os da
172.16.101.1 172.16.101.1 151 0x8000000C 0x003E89 3
172.16.102.2 172.16.102.2 977 0x8000000A 0x00E7E0 3
10.1.13.0 172.16.101.1 151 0x80000005 0x00A4CF 0
05-08-2011 10:50 AM
Okay lets do the following commands. We are going to use address-family on R1 for a bit more advanced configuration.
R1:
router ospf 1
router bgp 100
address-family ipv4
redistribute ospf 1
no auto-summary
no synchronization
exit-address-family
no ip route 172.16.103.3 255.255.255.255 10.1.13.3
R3:
router bgp 100
no synchronization
no auto-summary
05-08-2011 11:12 AM
Toshi,
it works now. The last culprit appeared to be the "synchronization" command in there. I thought it wasnt related in this scaniro, but it apperantly is. I wonder wny is that?
thanks,
Han
05-08-2011 11:32 AM
Han,
HTH,
Toshi
