Redistributing BGP into RIP
alban.dani
I am trying to redistribute some bgp routes into rip.
the configuration for the rip proccess is:
router rip
version 2
timers basic 5 17 17 17
redistribute static metric 5
redistribute bgp 20414 metric 5
passive-interface default
no passive-interface Vlan801
network 10.0.0.0
distribute-list 1 out Vlan801
distribute-list 1 in Vlan801
no auto-summary
ip access-list 1
deny 211.211.202.0 0.0.15.255
permit any
The bgp routes that the router learns via bgp do not get redistributed for some reason.
If I put static entries for the same routes then they do.
Why this behaviour?
thank you,
alban
5 Replies 5
tdrais
Level 7
Level 7
Make sure the BGP routes you are tring to redistrubute are EBGP routes. Also be sure the routes are in the routing table. It will not redistribute routes that are only in the bgp internal routing table.
The routes are both in the routing table and BGP internal routing table.
What exaclty do you mean by:
"Make sure the BGP routes you are tring to redistrubute are EBGP routes"
thank you,
Alban
The bgp routes are internal
bgp redistribute-internal shold do it right?
(with the proper care of course)
thank you
Alban
Yes that is how you get it to redistribute IBGP routes.
The main reason for this is to avoid routing loops but you will be fine as long as you are only redistributing in a single direction.
thank you
Alban
