Redistributing OSPF into BGP
GillieLucent
While redistributing ospf into bgp , I encountered the following behaviour :
Consider the existing config like:
router bgp 100
redistribute ospf match internal metric 77
Then I configured as below :
router bgp 100
redistribute ospf match external metric 44
when I gave 'show run' , it displays as below :
router bgp 100
redistribute ospf match internal external metric 44
is the expected behaviour, will the metric change to latest value ?(here from 77 to 44 ) .
Vijaybabu
globalnettech
Level 5
Level 5
this is indeed normal and to-be-expected behaviour, check the link below:
It is important to understand how the successive configuration change may alter your configuration. A new command with the match option does not overwrite the previous one but is added to it.
Modify the Redistribution Option in OSPF
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800943c5.shtml#modify
HTH,
GNT
