Redistributing routes learned from an external BGP peer into VRF
Benjamin_Smith
For reference, here's a picture of my network.
This is my first experience using MPLS and VRF's so be kind,
What we have is the two PE routers R1 and R6 connected to 'branches' that are in their own VRF on R1 and R6 called Client_A, they can talk to each other successfully which is what we want. Our main issue is we're trying to connect to a third branch configured on another network. We have our whole network configured in BGP 65111 and the other team has theirs in BGP 200.
We've had them push all of their routes into our OSPF and they're there in R3's global routing table and R3 can ping them successfully, our issue is getting the branches to ping the other 'branch' in their networks 'server' 209.165.212.35,
We've hit a wall trying to redistribute the routes learned from BGP into our VRF table.
As per the rules, this is nothing in production, just in a lab environment.
At the moment I'm mainly working on getting it working between Router 3 and Router 1 so I can reproduce this to R5 and R6.
R1:
hostname ISP-R3
vrf definition Client_A
rd 100:14
route-target export 1:1
route-target import 100:101
route-target import 100:102
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
ipv6 unicast-routing
mpls label protocol ldp
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Loopback10
vrf forwarding Client_A
ip address 99.99.99.99 255.255.255.255
interface GigabitEthernet0/0/0
description Connection to MLS1
ip address 10.1.1.37 255.255.255.252
negotiation auto
ipv6 address FE80::1 link-local
ipv6 address 2001:DB8:35AA:8::1/64
mpls ip
ospfv3 1 ipv6 area 0
ospfv3 1 ipv4 area 0
interface GigabitEthernet0/0/1
description Connection to MLS2
ip address 10.1.1.41 255.255.255.252
negotiation auto
ipv6 address 2001:DB8:35AA:9::1/64
mpls ip
interface Serial0/1/0
description connection to R5
ip address 10.1.1.25 255.255.255.252
ipv6 address 2001:DB8:35AA:7::1/64
mpls ip
interface Serial0/1/1
description Connection to R1
ip address 10.1.1.6 255.255.255.252
ipv6 address FE80::2 link-local
ipv6 address 2001:DB8:35AA:3::2/64
mpls ip
interface Serial0/2/0
description Connection to ISP B
ip address 209.165.200.5 255.255.255.252
mpls ip
clock rate 125000
router ospfv3 1
address-family ipv4 unicast
router-id 3.3.3.3
exit-address-family
address-family ipv6 unicast
router-id 3.3.3.3
exit-address-family
address-family ipv4 unicast vrf ISP-B
redistribute bgp 65111
router-id 123.123.123.123
exit-address-family
router ospf 1
router-id 3.3.3.3
redistribute bgp 65111 subnets
network 3.3.3.3 0.0.0.0 area 0
network 10.1.1.4 0.0.0.3 area 0
network 10.1.1.24 0.0.0.3 area 0
network 10.1.1.36 0.0.0.3 area 0
network 10.1.1.40 0.0.0.3 area 0
mpls ldp autoconfig
router bgp 65111
bgp router-id 3.3.3.3
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 1.1.1.1 remote-as 65111
neighbor 1.1.1.1 update-source Loopback0
neighbor 6.6.6.6 remote-as 65111
neighbor 6.6.6.6 update-source Loopback0
neighbor 209.165.200.6 remote-as 200
address-family ipv4
neighbor 209.165.200.6 activate
exit-address-family
address-family vpnv4
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
neighbor 6.6.6.6 activate
neighbor 6.6.6.6 send-community extended
exit-address-family
address-family ipv4 vrf Client_A
redistribute connected
redistribute static
exit-address-family
ip route 20.20.20.20 255.255.255.255 209.165.200.6
ip route vrf Client_A 0.0.0.0 0.0.0.0 Serial0/2/0
ip route vrf Client_A 25.50.212.35 255.255.255.255 Serial0/2/0
ip route vrf Client_A 209.165.200.4 255.255.255.252 Serial0/2/0
ip route vrf Client_A 209.165.200.6 255.255.255.255 Serial0/2/0
mpls ldp router-id Loopback0
R1:
hostname ISP-R1
rd 100:11
route-target export 100:101
route-target import 100:103
route-target import 1:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 10.1.1.9 255.255.255.252
ip ospf 1 area 0
negotiation auto
ipv6 address 2001:DB8:35AA:3::1/64
description Connection to Branch 1
ip address 209.165.200.1 255.255.255.252
negotiation auto
ipv6 address 2001:DB8:FFB1::1/126
description Connection to R2
ip address 10.1.1.1 255.255.255.252
ipv6 address 2001:DB8:35AA:1::1/64
description Connection to R3
ip address 10.1.1.5 255.255.255.252
ipv6 address 2001:DB8:35AA:2::1/64
router eigrp Client_A
address-family ipv4 unicast vrf Client_A autonomous-system 1
topology base
redistribute bgp 65111 metric 1000 10 255 1 1500
exit-af-topology
network 0.0.0.0
exit-address-family
address-family ipv6 unicast vrf Client_A autonomous-system 1
topology base
exit-af-topology
exit-address-family
router ospfv3 1
router-id 1.1.1.1
exit-address-family
redistribute static
router-id 1.1.1.1
exit-address-family
exit-address-family
exit-address-family
router ospf 1
router-id 1.1.1.1
network 1.1.1.1 0.0.0.0 area 0
network 10.1.1.0 0.0.0.3 area 0
network 10.1.1.8 0.0.0.3 area 0
mpls ldp autoconfig
router bgp 65111
neighbor 3.3.3.3 remote-as 65111
neighbor 3.3.3.3 update-source Loopback0
neighbor 5.5.5.5 remote-as 65111
neighbor 5.5.5.5 update-source Loopback0
neighbor 2001:DB8:FEED:2::1 remote-as 65111
address-family ipv4
exit-address-family
neighbor 3.3.3.3 activate
neighbor 3.3.3.3 send-community extended
neighbor 5.5.5.5 activate
neighbor 5.5.5.5 send-community extended
exit-address-family
address-family ipv6
neighbor 6.6.6.6 send-label
exit-address-family
address-family vpnv6
neighbor 2001:DB8:FEED:2::1 activate
neighbor 2001:DB8:FEED:2::1 send-community extended
exit-address-family
redistribute eigrp 1
exit-address-family
address-family ipv6 vrf Client_A
exit-address-family
logging origin-id hostname
logging host 10.1.1.90
Giuseppe Larosa
Hello @Benjamin_Smith ,
your interface to ISP-B on R3 belongs to GRT and not to VRF
mpls ip
clock rate 125000
later you attempt to define an eBGP session in VRF Client_A  with 209.165.200.6 but this should not work until you put the above interface in the same VRF.
Hope to help
Giuseppe
Giuseppe Larosa
mpls ip
clock rate 125000
Hope to help
Giuseppe
So the interface pointing towards the external ISP should be 'vrf forwarding Client_A' ?  we thought in the sense of an ISP simulation which is what we're semi trying to achieve, if an ISP had a connection to another ISP they would need to have multiple VRF's forwarding out.. wait I think I just answered my question, they would use sub interfaces and push vrf forwarding out that interface?
Yes
if your goal is inter AS MPLS VPN the use of back to back VRF mapped subinterfaces is the first option called option A
it is the simplest one but less scalable. There also other options called B, C, and AB. The idea is to use MP eBGP VPNv4 sessions.
see the following document
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_ias_and_csc/configuration/15-mt/mp-ias-and-csc-15-mt-book/mp-vpn-connect-asbr.html
Hope to help
Giuseppe
