ā06-01-2016 12:15 AM - edited ā03-05-2019 04:08 AM
Can someone confirm if the below is correct. The goal is to deny default from being redistributed, but allow everything else to be redistributed. I have no LAB kit to hand :(
ip prefix-list DENY_DEFAULT seq 5 deny 0.0.0.0/0
ip prefix-list DENY_DEFAULT seq 10 permit 0.0.0.0/0 le 32
route-map BGP_TO_EIGRP permit 10
match ip address prefix-list DENY_DEFAULT
set metric 1000000 1 255 1 1500
router eigrp 826
redistribute bgp 65512 route-map BGP_TO_EIGRP
ā06-01-2016 03:32 AM
Good day.
What is your BGP table size? If you redistribute Full View, you will have problem.
Best regards, Alexey Nesterkin.
ā06-01-2016 09:59 AM
charles,
That looks right. Be careful with how many prefixes you have in your BGP table as that could be an issue.
ā06-16-2016 03:31 AM
I can confirm this is correct and does work
