reducing routing tables using stub areas
ohareka70
Level 3
Level 3
I would like to reduce the number of default routes on all of the routers on our corporate network which is around 60 sites.  The routing tables are too big and i am running OSPF.  Is it possible to create stub routers on the routers that are off the core network (Layer 3 switches) and then they will just have a default route out of their router to the layer 3.
At the moment if i do a show ip route the table is huge because it has learned every route on the network.  I just want it to know a default route to the next hop which should be the core.  Their are about 6 core router sites on the network.
Any advice is welcome.
2 Accepted Solutions
Jon Marshall
Kevin
If they are in different areas then yes you can use stub or totally stubby area configuration on those routers which would dramatically reduce the routing table size.
Be aware that there are certain restrictions for stub areas though ie.
1) you cannot create a virtual link across a stub area
2) a stub area can contain an ASBR - if you have an area with an ASBR you want to make a stub area then make it an NSSA.
As i say all the above assumes the routers you want to  make stub routers are in different areas from your core routers.
Jon
ohareka70 wrote:
I was thinking of putting this onto the router that hangs off the core (area 0 layer 3 switch) and also putting the same config on the other routers that have a serial link to the first router.
conf t
router ospf 1
area 1 stub no-summary
so i should just be left with connected routes and a default route back into the network thereby reducing the size of the network tables.
What do you think?
Kevin
Kevin
Yes that will work. Just remember that all routers in area 1 will need the same config ie. they msut be configured as stub routers also.
Jon
5 Replies 5
Jon Marshall
Kevin
Jon
conf t
router ospf 1
What do you think?
Kevin
conf t
router ospf 1
What do you think?
Kevin
Kevin
Jon
paolo bevilacqua
Huge like what, 200, 300 or how many routes ?
Consider routers and switches handles routinely hundred of thousands.
The size of routing table doesn't matter much.
Of course in stub locations there is no meaning having it, but even if you do, nothing bad happens.
What matter is if you are happy with the network setup in its overall aspect of performances, stability,  administration overhead.
Its about 500 routes in each table.  Its interesting that you think the routing table doesnt matter much - maybe you are right about this.  I take it i dont put a stub area on the core sites?
Kevin
