Redundancy on Cisco AS
rezamira
dear guys
hi
i have a question about redundancy scenario on cisco ASRs
as like as cisco 6807 that support VSS for make 1 bigger switch with 2*6807 or stack on C3750 or C3850, is there any same technology for Cisco ASRs or not?
the ASR routers support a feature called Interchassis High Availability:
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/sbcu/2_xe/sbcu_2_xe_book/sbc_interHA.pdf
Dear Friend
Thanks for you reply
i checked your sent doc, please tell me this model is same as VSS on cisco 6807-X?
because i found its a little different
Reza
