WAN to LAN - Destination NAT using hostname
i've a local DNS Server (reacheable only inside the company) with Round Robin DNS record (one DNS record with 3 IP addresses) :
  • DNS RR record : server.mycomany.com
  • IP Addresses : 10.10.20.1 / 10.10.20.2 / 10.10.20.3
In a host perform a DNS request for server.mycomany.com, my DNS server returns (randomly) one of these IP : 10.10.20.1 / 10.10.20.2 / 10.10.20.3.
I would like to create a destination NAT (from WAN to LAN) by using the record name instead one of the 3 IP addresses (in order to keep the load balancing system).
I'd like implement something like this :
description "NAT FROM WAN"
destination {
     address 172.18.225.132
inside-address {
     address "server.mycomany.com"
Is it possible ?
rais
Level 7
Level 7
You can assign a NAT pool for inside addresses with option 'rotary'. When the client comes in it will be assigned one of the addresses in the pool.
 ip nat pool name start-ip end-ip {netmask netmask | prefix-length prefix-lengthtype rotary
HTH.
Thank you for reply. I think that this could be a good solution for us.
Can you confirm that is impossible to use the "hostname" ?
Thank you
