Redundancy to Single ISP
NetInvKln
Hi Experts,
First and foremost, what I have are 2 x 7204VXR (Gateways), 1 x 4507R-E (Coreswitch), and our ISP have 7609.Got some issues with redundancy with our ISP.
                                        7609
                                        I     I
                                        I     I
                               7204-A    7204-B
                                    |    vrrp   |
                                    -4507R-E-
                               internal network
Both outside interfaces of 7204 gateways are connecting to 7609 with different public ip block.
I used VRRP for my internal nework and failover have been tested working.
Even tried to remove link of 7204-A and 7609, the failover works perfect.
But somehow we're facing a problem:
- If I shutdown/ remove the link between my 4507R-E and 7204-A (primary gw_higher vrrp priority), vrrp redundancy/failover still works but internal network's internet connection goes down.
I asked our ISP and the route commands they put in their 7609 are as of follows:
ip route 3.8.8.0 255.255.255.0 3.4.4.4 name TO CUSTOMER LINK 1
ip route 3.8.8.0 255.255.255.0 3.3.3.3 2 name TO CUSTOMER LINK 2
And if they're trying to use Reliable Static Routing Backup Using Object Tracking, the internal network's internet connections is intermittent....alternate 4 ping reply and 4 timeout.
Note: IP used are sample only
Please advise why we're having such problem.
Thanks in advance.
6 Replies 6
cadet alain
I had overlooked the higher AD on second static route
So with their config they only had 1 path the echo-replies would follow which goes to 4.4.4.4 ( is 7204-A ?)
What type of L2 is there between ISP and your routers?
which router is 4.4.4.4 and which is 3.3.3.3 ?
which type of tracking did they do ?
Regards.
Alain
So with their config they only had 1 path the echo-replies would follow which goes to 4.4.4.4 ( is 7204-A ?) YES
What type of L2 is there between ISP and your routers? NONE
     - 4.4.4.4 is 7204-A outside interface going to ISP 7609
     - 3.3.3.3 is 7204-B outside interface going to ISP 7609
Below is what they've done (3.8.8.4 is 4507R-E IP):
ip sla monitor 1
type echo protocol ipIcmpEcho 3.8.8.4
timeout 1000
frequency 3
threshold 2
ip sla monitor schedule 1 life forever start-time now
track 123 rtr 1 reachability
access list 101 permit icmp any host 3.8.8.4 echo
route map NI-LOCAL-POLICY permit 10
match ip address 101
set interface gig 8/4 null 0
ip local policy route-map NI-LOCAL-POLICY
ip route 3.8.8.0 255.255.255.0 4.4.4.4 track 123
They also done below config, this but didn't work as well, 50% success internet connectivity:
ip sla 1
icmp-echo 3.8.8.4 source-interface Gig2/4
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
they should second config but like this:
p sla 1
timeout 2000
threshold 2
frequency 3
Regards.
Alain
Didn't worked as well Alain.
I'm thinking of having the ISP make a new VLAN going to my network and have both links in one ip block, where they should make their ports Layer 2.
Then create another VRRP in my gateway's outside interface.
Then they should create a route to my internal network (which is also public ip block) pointing to the virtual ip of the new vrrp.
Would this cause any problem?
it should work. Can you ask them to do debug  track and debug ip routing on their side and you do debug ip packet  199 where 199 is ACL permitting ICMP only and also debug vrrp.
They should track the  the IP address of the interface of  7204-A connected to  4507-RE and source it from the interface connected to 7204-A.
Right now I don't think your second solution could cause any problem.
Regards.
Alain
