Redundant ADSL to MPLS
Mounirabdallah
Network setupPicture attached.
Objective:
1. ALL traffic from VLAN1 and VLAN2 in branch office to headquarters is routed via Dialer1. If dialer1 is not available then all traffic is routed via dialer2.
2. ALL traffic from VLAN1 and VLAN2 in branch office to the internet is routed via Dialer2. If dialer2 is not available then all internet traffic is routed via dialer1.
This configuration is yet to be going into production but I am not sure whether it will work. Please verify which Option makes more sense.
My Configuration Option 1:
uilding configuration...
Current configuration : 3291 bytes
! Last configuration change at 21:59:11 UTC Thu Mar 9 2017 by plesi
version 15.3
hostname Busways_kempsey
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 $1$QWCt$Fl4eD6Nu.WOFoDdFW2hz5/
enable password plesi1
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
vpdn enable
license udi pid C887VA-K9 sn
controller VDSL 0
interface ATM0
description ### DSL1 ###
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
description ### RESERVED_FOR_VOICE_LAN ###
no ip address
shutdown
interface FastEthernet1
switchport trunk allowed vlan 1,2,101,1002-1005
switchport mode trunk
no ip address
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
description ### DSL2 ###
switchport access vlan 3
no ip address
no cdp enable
interface Vlan1
description ### ###
ip address 10.1.11.1 255.255.255.0
ip virtual-reassembly in
ip tcp adjust-mss 1452
ip policy route-map RM-TO-HEADQUARTERS
interface Vlan2
description ### PORT_MACQUARIE_WIFI_LAN ###
ip address 192.168.11.1 255.255.255.0
interface Vlan3
description ### VLAN DSL2 ###
no ip address
pppoe enable
pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp chap hostname xxxxxxxxxxxx
ppp chap password 0 xxxxxxxxxxxxx
interface Dialer2
description ### INTERNET ###
ip mtu 1492
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
ppp chap hostname xxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip access-list extended ACL-ROUTE-TO-HEADQUARTERS
permit ip 10.1.11.0 0.0.0.255 10.1.1.0 0.0.0.255
permit ip 10.1.11.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.11.0 0.0.0.255 10.1.1.0 0.0.0.255
permit ip 192.168.11.0 0.0.0.255 192.168.1.0 0.0.0.255
route-map RM-TO-HEADQUARTERS permit 10
match ip address ACL-ROUTE-TO-HEADQUARTERS
set ip next-hop dialer1
set ip next-hop verify-availability
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 0.0.0.0 0.0.0.0 Dialer1 10
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
atm ilmi-keepalive
pvc 8/35
interface Ethernet0
no ip address
shutdown
no ip address
shutdown
no ip address
no ip address
shutdown
no ip address
no cdp enable
interface Vlan1
description ### ###
interface Vlan2
description ### ###
interface Vlan3
no ip address
pppoe enable
interface Dialer1
description ### Headquarters ###
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
ppp chap hostname
ppp chap password
interface Dialer2
ip mtu 1492
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
ppp chap hostname
ppp chap password
no ip http server
track 1 ip sla 1
track 2 ip sla 2
ip sla 1
icmp-echo 10.250.38.10 source-interface Dialer1
timeout 1000
frequency 5000
ip sla schedule 10 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface Dialer2
timeout 1000
frequency 5000
ip route 10.1.0.0 0.0.255.255 Dialer1 track 1 1
ip route 192.168.0.0 0.0.255.255 Dialer1 track 1 1
ip route 10.1.0.0 0.0.255.255 Dialer2 track 2 10
ip route 192.168.0.0 0.0.255.255 Dialer2 track 2 10
ip route 0.0.0.0 0.0.0.0 Dialer2 track 2 1
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1 10
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Francesco Molino
Both solutions will work.
This depends also on the image your using on your router but I bet you already checked that.
Pbr will allow you granular routing decisions based on the source subnet if you plan having more subnets.
On your actual design, you can decide either to use one or other.
I'll prefer using pbr in that situation because you can precisely select which traffic goes where in case of growth.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
