03-11-2017 06:02 AM - edited 03-05-2019 08:10 AM
Hi, As we know, ASR9K has a command "commit label xxx". The label is for us to easily rollback to the previous configuration labeled by the number xxx. The command records all commands used in the router. My question is, how can we see Configuration labeled by "commit label xxxxx" in ASR9K? Thank you
Solved! Go to Solution.
03-11-2017 08:50 AM
Yes, you can use it
You can see the label through: show configuration commit list
Example:
commit label TEST
#sh configuration commit list
Sat Mar 11 10:47:56.595 UTC
SNo. Label/ID User Line Client Time Stamp
1 TEST
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/getting_started/configuration/guide/asr9k/asr9kcnov.html#pgfId-1260803
Please rate the comment if it is useful, thanks.
03-11-2017 08:50 AM
Yes, you can use it
Example:
commit label TEST
1 TEST
03-13-2017 04:55 PM
Thank you
03-13-2017 05:02 PM
You are welcome, have a great day!
