Redundant path for data flow
sukhjits8511
Hi all cisco gurus, pls suggest something on the scenerio am trying to work on.
Its complete static routing no routing protocol running....
Router Y is connected to RouterA via ethernet0,router A is connected to router A1 with a 2Mbps serial link and
Router Y is connected to RouterB via ethernet1, router B is connected to routerB1 with a 2Mbps serial link.
If the link from routerA to routerA1 goes down, i want that the Router Y should divert the traffic automatically to the other link ( via routerB and routerB1)
Thanks in advance
rakshitj
I think GLBP would work in your case.
refer GLBP samples from cisco.
vbhadula
Connect Router A and B and use floating static routes for the redundency.
Amit Singh
Hi....
Thanks for the reply amit.
If i connect router A with B via serial back to back cable then...and put floating route..then if the link terminated on router A goes down the traffic will shift to router B and take the alternate floating route but in the other case..
If the link terminated on routerB fails then how will the router A know that the link terminated on router B has failed as the link AB between both the routers if up.......
Is there a particular reason you can't just run a routing protocol among all five routers? That would make everything you're looking for "just work." With such a small network, you could use EIGRP, RIP, OSPF or whatever.
Good luck and have fun!
Vincent C Jones
www.networkingunlimited.com
