06-08-2012 07:05 AM - edited 03-04-2019 04:36 PM
Hi ,
i am using cisco 2821 router at the edge in my network where the WAN link is terminated.
i want to configure Redundancy . So will 2821 support ? If yes what is the another router .Is it the same series or different for redundant configuration.
Saroj
06-08-2012 07:12 AM
It can be any router. But 2800 series would be good. Which redundancy mechanism are you planning for? Could you paste a diagram or something?
But to make it short any router would work 1800, 1900, 2800, 2900 so on..as unlike firewall it wont be maintaining the state information.
06-08-2012 09:48 AM
The Present Network Diagram is like at the edge Cisco 2821 router where the link terminated.
Behind the Router the cisco ASA 5510 is connected then the ASA is connected to the distribution Switch cisco 3560 where all the VLANS Configured .The L3 is connected to the Access Layer switches.
i need Redundancy at the edge using HSRP. Please advice.
Saroj
