Reestablishing the vpn tunnel when the External IP change
hani hoseen
hello all,
I have an issue regarding a setup of a VPN connection betwen tow sites
one site is having a statis IP
the other site is using a 3G modem with a dynamic public IP
i hve attached a brief layout of the setup for more clarification.
i used a GRE tunnel betwen the tow sites and the VPN is working fine.
the only issue i have is that in case the 3G modem public IP change due to a restart or any other reson ,
the VPN is not reestablishing because the ip of the router (10.10.1.2)  is not changing when the public ip of the 3G modem is changing ,
and thus the router keep thinking that the tunnel is up ,
the only solution is manualy having to clear the tunnel  then the new tunnel will establish.
is there any workout to solve this issue
Thank you for the great support
Tagir Temirgaliyev
from router on 3G side tunnel sousce musst be interface Cellular
interface Tunnel14
ip address 10.x
tunnel source Cellular0
tunnel destination 192.168.102.1
tunnel protection ipsec profile vpnprof
on central router
interface Tunnel14
ip address 10.1.x
tunnel source 192.168.102.1
tunnel mode gre multipoint
Thanks for the reply  ttemirgaliyev
i think i made the layout clear that the 3G modem is a seperate device (not a 3G Card)
Thanks again
hani hoseen
after second check on the setup ,
the tunnel is actully re-establishing but the eigrp process is taking too much time ( around 6 minutes ) to form the neighbors relationship and add the networks to the routing table.
*Jun  6 20:16:02.039: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is down: holding time expired
*Jun  6 20:16:16.119: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is up: new adjacency
*Jun  6 20:16:16.131: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is down: Interface Goodbye received
*Jun  6 20:16:16.167: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is up: new adjacency
*Jun  6 20:16:16.323: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is down: peer restarted
*Jun  6 20:16:20.963: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is up: new adjacency
*Jun  6 20:17:07.943: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 50: Neighbor 172.16.16.2 (Tunnel0) is down: holding time expired
any suggestions
