Reg:2800 router isp failover and loadbalance
dhanikonda
Dear sir,
iam having 2800 router iamhaving 2 leased line (v.35)each capacity is 2mb both leased lines r from same isp .now we want to achive loadbalance and isp failover.
plz give me some examples.
srini
paolo bevilacqua
paolo bevilacqua
That is your configuration example:
http://cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
I believe in this your case the routing is made by static routes.
To achive load-balance the ISP needs to configure your lan address in both links and you need to set a default static route to both links. Its recommended to active CEF in your router.
Ex:
CPE > Link1 - Ip x.x.x.x. ISP > Link1
CPE > Link2 - Ip y.y.y.y. ISP > Link2
In CPE ( Your Router )
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 0.0.0.0 0.0.0.0 y.y.y.y
ip cef
Plz Rate.
