reg:3745 router
dhanikonda
Dear sir,
Iam having 3745 router in that iam getting router hanging problem.so iam attaching my config plz go through that and suggest me the best way to trableshoot.
Thanks&Regards
srini
5 Replies 5
paolo bevilacqua
Which exact IOS are you running ?
Dear sir,
Thanks for ur reply and in my router we r using the below.
------------------ show version ------------------
IOS (tm) 3700 Software (C3745-JS-M), Version 12.3(10a), RELEASE SOFTWARE
(fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 22-Oct-04 18:53 by kellythw
Image text-base: 0x60008AF4, data-base: 0x61F20000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
Orchid uptime is 3 hours, 31 minutes
System image file is "flash:c3745-js-mz.123-10a.bin"
cisco 3745 (R7000) processor (revision 2.0) with 505856K/12288K bytes of
memory.
Processor board ID JMX0704L195
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
4 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31296K bytes of ATA System CompactFlash (Read/Write)
Thanks&Regards
srini
a
Dear sir,
plz go through the below and do the need fullto me.
(fc2)
memory.
Bridging software.
srini
Please upgrade to latest 12.3 and check again.
