Reg: IOS image 12.4(11)t
manjunath99
I  just need some  information on IOS image 12.4(11)t,like whether it will support Cisco routers like 7200,3600,3800 etc.
And also whether it will support features like IPv6,MPLS,bgp and etc.
Please help me on this..
Manjunath
Mahesh Gohil
Level 7
Level 7
Hello Manjunath,
12.4(11)T is end-of life and is not available for download (atlease I did not found it on cisco.com). I would recommended below IOS for the platform
you mentioned which support your needs
7200/3800: 12.4(24)T4
3600: 12.4(15)T7
Mahesh
Thanks Mahesh....will those IOS Image support all the features...
Please give the link,where can i get the proper document for these image...
And Reg.. IOS 12.4(11)T ,you told that it is not available for download..if i  get in touch with Cisco will i get the image..
Hello manjunath,
To know features supported software wise you may take help from feature navigator
www.cisco.com/go/fn
you can also find release notes of IOS product wise by selecting product line below is for 7200
http://www.cisco.com/en/US/products/hw/routers/ps341/prod_release_notes_list.html
hmmm.  i don't think so.
Mahesh
Manjunath
12.4(11)T and 12.4(24)T4 are release levels. Within each release level are multiple images with each image representing a different feature set. The issue of what features are supported relates to which feature set is being run. Some feature sets, such as IP BASE, support only a limited set of functionalities. Other feature sets, such as Advanced Enterprise, support a very wide set of functionalities. Once you are clear of what set of functionalities you need you can use the feature navigator to find release levels and feature sets that include those features.
Rick
Rick
