reg:mpls
vasuramnet
Dearsir,
one of customer is having 2821 router in head office and with 4 k.m range he was having branch office like that he was having 5 remote locations.in all locations hawas taking vpn lines to connect mpls network .now head office he was using 2821 router and remote locations which router is suggstable and which ios is required to use mpls vpn network.
if any write up for mpls network pls send to me.Iam attaching the network diagram also.
regards
srinivas.D
9246571397
mohammedmahmoud
Level 11
Level 11
If you are talking about taking MPLS VPN service from a provider, then the CE router doesn't have to be MPLS aware at all, the CE router in this case just have layer 2 encapsultaion and IP addresses under the interfaces.
Please don't hesitate for any further questions.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Dear sir,
My customer is taking bsnl vpn lines for this ce router no ios required and remote side which router is suggestable for this connectivity and point to multipoint any pdf is there plz kindly advice me.
regards
srinivas.D
