WS-SUP720-3B and CF-Adapter-SP question
lunarsystems
Hi All!
I am not sure what the CF-Adapter-SP on the WS-SUP720-3B is and is it a bit of hardware connected to the SUP720 or is it part of software. Also, I had been told that the presence of the CF-Adapter-SR on the SUP depends on the spec of the SUP720. Can anyone tell me what it is please?
Andrei
Amit Singh
Andrei,
CF-Adaptor-Sp is a hardware Compact flash card which comes with Sup-720 and is used instead of older Chip based Flash.This CF adaptor-SP comes with more memory size than the older Flash.
The CF-Adapter-SP is the top level part number for the Compact Flash adaptor Kit. The CF-Adaptor-SP is the adaptor, this comes as the
default for the SUP720-3B's shipping today.
HTH,Please rate if it does.
-amit singh
Thanks Amit, I makes sence now.
