reg-vpn
ramnetindia
Dearsir,
iam having 1721 router in that 12.2 ios is there .on 1721 router is it possible to do vpn point to point.if it is possible how can i do that can i get any examples.
srinivas.D
spremkumar
Level 9
Level 9
Hi Srini
If you are thinking off IPSEC VPN then you need to make sure that your ios code have the supported feature set to configure ipsec in your router.
do post out the file name of the ios code installed in your router ..
also you can make use of feature navigator to find out the same..
regds
Dear sir,
in my 1721 having c1700-k9sy7-mz.122-15.T9 ios . is it supports for vpn .if not which ios supports for vpn only point to point not ip sec
plz give me some example how to configure point to point
srinivas.D
Hi Srini
If its a simple point to point to link then you might go on with simple plain connectivity without any additional vpn config.
But still if you want to make use you can think off going on for GRE tunneling which is the simplest of encapsulation methods available.
regds
