Regarding IGP and BGP
ncnaveen_arasu
Hi team
Why we run IGP (OSPF) and BGP in MPLS VPN envirornment. wether runing BGP is not sufficient, why we need IGP also. PLease clarify in brief
Raju Sekharan
Hi Naveen,
Are you talking about OSPF as PE-CE protocol or OSPF used in the MPLS service provider network
Raju Sekharan
Hi Naveen,
Hi Rajs,
Thanks for the reply, iam talking about the OSPF used in the MPLS service provider network. When we run BGP between the loopbacks between PE and P router. why we run again an OSPF or some IGP protocol.
cadet alain
you do your PE-PE BGP peering over Loopbacks and so you need an IGP for the peering and also  a MPLS router will advertise labels only for prefixes it has in its routing table( so in CEF table).
Regards.
Alain
sivai2tech
Naveen,
Here is why we need IGP in the core.
                             igp
CE1---------PE1----------P----------PE2----------CE2
                            mpls
1.> To establish MPBGP session b/w PEs.
2.> To establish LSP.(signalling is based on the igp that you use in the core).
Thx!
~S
