# REGEX in CISCO iOS, iOS XE #
REGULAR EXPRESSION, a filtring tool based on ::
Special characters, Characters classes, Sets, Groups, Flags.
are all these ASPECTS availible in cisco iOS, iOS XE ?
is there other unknown characters  like underscore "_" ?
Best Regards!
6 Replies 6
Giuseppe Larosa
yes regular expressions are available in IOS, IOS XE and IOS XR and NX-OS.
There are  two main applications for regular expresssion in IOS:
a)  Filtering BGP advertisements using regular expressions applied to the AS path attribute seen as a sequence of characters
see
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13754-26.html?dtid=osscdc000283
b) using regular expressions in show commands to filter show output.
https://learningnetwork.cisco.com/s/question/0D53i00000KssVx/regular-expression-in-cisco-show-commands?dtid=osscdc000283
Hope to help
Giuseppe
i'm using regex to filter show commands this time !. it works almost fine, just for some cases ::
* the digits specification \d does not work
* how to escape characters  \.
* how to use ?=non-greedy as it is considered as help on cisco iOS
* is it possible to provide an underscore "_" exemples !
best regards!
in order to make the regex to search for a special character "literally" the character has to have a \ before
show ip int br  | inc   gigabitethernet0/0/0\.*
should show all subinterfaces of gigabitethernet0/0/0.
This trick should work also for '_' underscore to match it literally try to use \_
Hope to help
Giuseppe
Leo Laohoo
Please be very, very careful when dealing with IOS-XE and REGEX, particularly the "pipe".  This is due to CSCvo06817.
using grep after the terminal shell command, does is offer more advantages or it's the same as |Pipe include ...
best regards!
"grep" option only works for Nexus OS.  The bug I've pointed out is for IOS-XE.
