Reinstall IOS on router 871 W
cephasattica
I have an Router 871W with no bootable image file. I tried to upload a new IOS using hyper terminal and xmodem but get an error message ERR:Image size exceeds free flash space.
How do i re-install the IOS?
I have attached text from hyper terminal.
Laurent Aubert
You need to delete your corrupted file from ROMmon before uploading the new one via xmodem
Please follow the steps described here:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_tech_note09186a008009429e.shtml
Laurent.
Leo Laohoo
You can also try to use the "tftpdnld" feature.
Disaster Recovery with TFTP Download
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/rommon.html#wp1020643
Hope this helps.
route2null
The error makes me think your IOS of choice is > than the total amount of flash?
