Reload Cisco Router
Hello
How can i reload a router with this kron?
The problem is that i have to confirm the reload. How can i dissable this command?
kron occurrence reload-router at 13:00 recurring
 policy-list reload-router
kron policy-list reload-router
 cli reload
It will not reload .
Julio E. Moisa
It looks good, how is set up the clock time on your device? Also you could try using cron + eem:
event manager applet ScheduledAction
event timer cron cron-entry
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Why do you want to reload the router every day? You should better correct your problems instead of reloading the router on a daily basis.
The router is a LTE device and after a long period the internet crash and did not work. After a reload it works fine.
I can shutdown the cellular interface and restart it but this doesn`t help. So i decide to reload the router.
Do you have a better idea?
Have you tried updating the IOS? These are often software-problems.
Yes i have the latest version. I think the problem is the provider.
The provider sometimes make some updates i think and then the router hangs up.
Julio E. Moisa
