Remote site Internet access over MPLS network
Haitham Elkot
i already connected all my HQ and branches with the ISP with a L3VPN connection , providing NAT at the HQ  , all my branches get internet through the HQ ,, when I tracert to 8.8.8.8 (google) the packet gets to a hop (this hop related to a router at the core of the ISP routers ) and died, however all my internal network packets are routing just fine. What am I missing here?
9 Replies 9
it is unclear what you are asking: a traceroute to 8.8.8.8 dies...where ? Post the relevant configurations...
a traceroute to 8.8.8.8 dies...where ?  at the branch has  the problem that i can`t access internet at it , also Note i have class of service and policer configuration for each branch at the HQ router . Unfortunately i didn`t have the config file now
at a minimum we need to know what kind of topology you have (e.g. DMVPN)...can no branch access the Internet or just one branch ?
what kind of topology you have  ? MPLS L3VPN connection between all my HQ , branches and the ISP network  , this issue related only to one branch not all
Do you have access to the branch, can you check e.g. BGP connectivity ?
Do you have access to the branch ? Yes i  have reliability between the HQ & the mentioned branch ,
for example as per attached L3VPNL3VPN
Are you using Juniper routers ? Either way, if you can access the branch, post the output of 'show ip route' and the running config...
at my side Cisco Routers
Compare the configuration of one of the working branches with the configuration of the branch that has no connectivity...
