Remote vpn can not access inside user.
teymur azimov
Hi dears. i configurated remote vpn at asa 5510. i attached my network topology.
ip local pool VPNPOOL 192.168.200.1-192.168.200.100.
i can access servers with remote vpn which they located at dmz zone at asa(write nonat access-lsit) but i can not 192.168.193.0 subnet at asa.
i configurated proxy server. my proxy server inside interface get ip address my dmz zone(172.16.10.254) and outside is ip adddress asa outside interface
(10.0.0.254).
the users (192.168.193.0/24) go internet from proxy server.
ASA config:
interface Ethernet0/0
description connect to RTR1 inside
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0 standby 10.0.0.3
interface Ethernet0/1
description connect to CoreSW
nameif inside
security-level 100
ip address 172.30.30.1 255.255.255.0 standby 172.30.30.3
interface Ethernet0/2
description DMZ zone connect mail server
nameif DMZ
security-level 50
ip address 172.16.10.1 255.255.255.0 standby 172.16.10.2
route inside 192.168.193.0 255.255.255.0 172.30.30.2 1
192.168.193.0 is user vlan and created at core switch. i want to access 192.168.193.0 subnet when connect remote vpn but i acn not access.
static (inside,DMZ) 192.168.193.0 192.168.193.0 netmask 255.255.255.0
i write nonat access list but it is not help me.
how i solved this issue?
please help me
andrew.prince
Level 10
Level 10
I notice this config line
Which means you have a L3 routing device in the mix.  Does 172.30.30.2 know that 192.168.200.1/24 is via
172.30.30.1??
Also post you no-nat config.
hi
yes i have ip route 0.0.0.0 0.0.0.0 172.30.30.1 at core sw
ai think the this defualt route must  help me to know 192.168.200.0 subnet. but i can not access 192.168.193.0 subnet with remote vpn.
the 192.168.200.0 vpn subnet at asa and 192.168.193.0 are created at core sw
int vlan 393
ip address 192.168.193.1 255.255.255.0
the users port which is access vlan 393 they default gateway 192.168.193.1
please help me
OK firstly using a 0.0.0.0 to catch a 192.168.193.0 is like using a cannon to kill a fly.........a little to much.
Remove the "ip route 0.0.0.0 0.0.0.0 172.30.30.2" and replace it with "ip route 192.168.193.0 255.255.255.0 172.30.30.2"
The on 172.30.30.1 make sure there is a route like "ip route 192.168.200.0 255.255.255.0 172.30.30.1"
See if that helps.
Let me ask you a question here.
Is your remote VPN user able to acess the other networks like the DMZ etc on the ASA.? What I am trying to ask is if your VPN remote user is able to access other networks without any issues and its just this 192.168..193.0 not accessible.
Also, I dont see any ACL to permit traffic between 192.168.200.1-192.168.200.100. and 192.168.193.0/24
on your Ethernet0/1 you need to add an ACL to permit . Although your inside network is trusted and security level is 100 , I believe the VPN users are not. In the ASA if you dont specifically mention the ACL's then the traffic will be dropped.
