Remove 4 Byte BGP Private ASN
How do you remove 4 byte Private BGP ASN as you advertise the prefixes to your ISP?
I already tried neighbor x.x.x.x remove-private-as command.  This command only removes 2 byte private BGP ASN.
Within my environment, we use both 2 byte private ASN and 4 byte private ASN.  On our border router to the ISP, we use the above command and it looks like it only works for 2 byte private ASN and not the 4 byte ones.
Thanks for the help.
Giuseppe Larosa
Hello network2004@gmail.com ,
what is your border router ?
post a show version
as a workaround you could try to use an aggregate-address with summary-only option as an attempt to remove the 4 bytes private AS numbers from the AS path attribute. This might be possible or not in your scenario.
Hope to help
Giuseppe
6 Replies 6
inderdeeps
Level 4
Level 4
network2004@gmail.com : Are you using asnotation for 4 Byte BGP number ?
I briefly read about it and I am not sure what asnotation does.  Could you explain how to use asnotation?  thanks.
So neighbor x.x.x.x remove-private-as command removes 4 byte private BGP ASN ?
Giuseppe Larosa
post a show version
Hope to help
Giuseppe
Thanks Giuseppe.   Aggregate with summary only is also what I did in the lab too.  I see that Juniper has the option to remove 4 byte private ASN and I just want to double check if Cisco has the same option too.
