Remove a static NAT but the static route remains in the routing table
JOSEPH GAYNOR
For a test added the following:
Ip nat outside source static 10.151.112.9 10.226.133.219 add-route
At test conclusion issued the following commands:
no Ip nat outside source static 10.151.112.9 10.226.133.219 add-route
clear IP nat trans
cle ip route *
Issue:
show ip route
Routing entry for 10.226.133.219/32
Known via "static", distance 1, metric 0
Redistributing via eigrp 99
Routing Descriptor Blocks:
* 10.151.112.9
Route metric is 0, traffic share count is 1
I've also deleted and re-added the route for 10.151.112.0/24 and 10.226.133.0/24.  Verified the outside source static statement is gone when I do a show run. No change in status.
router is a ISR4321/K9 running bootflash:isr4300-universalk9.16.09.03.SPA.bin
any ideas short of reloading the router?
First, let me thank you for your continuous feedback.
The NAT is not the issue. Actually the IP that was being NATed with that statement is no longer being NATed.
Traffic is running as it should, this just appears to be some sort of ghost entry in the routing table.
I was looking around in Cisco and found this: - not exactly my problem, but very close. I'm just not using the no-alias keyword.
Bug SearchCSCvk13358
Help | Feedback Feedback
outside NAT Add-route with no-alias cause permanent static route
CSCvk13358
Description
Symptom:
Static route added by NAT add-route option is not cleared after remove NAT config.
Conditions:
After config and unconfig of no-alias/add-route static NAT CLI an static route is permanently added in the routing table and not getting removed.
ip nat outside source static 192.168.21.20 192.168.121.70 no-alias add-route
no ip nat outside source static 192.168.21.20 192.168.121.70 no-alias add-route
S 192.168.121.70 [1/0] via 192.168.21.20 >>>>>>>>>>>>> Route not removed after removing CLI
Workaround:
Reloading router.
7 Replies 7
--> Redistributing via eigrp 99
What EIGRP neighbors is this being redistributed to ? Chances are that it is coming back from there...
The eigrp neighbors are not seeing the route.
The route table on the offending router lists the route as static
S 10.226.133.219/32 [1/0] via 10.151.112.9
Hello
@JOSEPH GAYNOR wrote:
show ip route
* 10.151.112.9
Sh ip route static
clear ip nat trans * force
Kind Regards
Paul
# cle ip nat trans * force
% Invalid input detected at '^' marker.
Force is not an option.
what if you remove the 'ip nat outside' and 'ip nat inside' statements from all interfaces (temporarily of course) ?
CSCvk13358
Description
Symptom:
Conditions:
Workaround:
Reloading router.
the reload is what we wanted to avoid...looks like there is no other way...thanks for sharing the bug info !
