Remove existing static IP port forwarding
Ridhwan
I'm trying to remove existing forwarded IP. I'm unsure on how to do it.
 I tried "no ip nat inside source static 192.168.x.x 210.x.a.b extendable"
Got the "% Invalid input detected at '^' marker." shown at "i" on letter ip.
Thanks in advance!
sometimes a static NAT entry cannot be cleared because it is in use. Try the following: cut and paste the below into your router (obviously, change the 'x.x' to your real IP address first.
clear ip nat translation
conf t
conf t
You save me. Thank you!
Just to add on that it's missing * at the end of "clear ip nat translation".
