Remove Private AS not working
CHARLES HEUPEL
I'm having an issue with the remove-private-as community.  We have a Customer who is dual homed to two of our routers and they are using a Private AS number.  When configuring my bgp session to them, I added the neighbor x.x.x.x remove-private-as but it doesn't seem to be working.  I know the router will not remove the private as if there is a mixture of public and private AS numbers but I don't believe we have that issue.  Any ideas on why we're not removing the AS number?  Diagram is attached and configuration is below.
RTR-1
router bgp "public-as"
neighbor x.x.x.x remote-as 65512
address-family ipv4 unicast
neighbor x.x.x.x activate
neighbor x.x.x.x default-originate
RTR-2
Hello Charles,
Looking at you toplogy, and the config, you are applying the removel towards the private ebgp peers,
AS65535                    AS10                                AS20
As path (Private) ← remove As path (private) ---- AS path only
It should be:
AS65535                    AS10                                 AS20
As path (Private) --- remove As path (private) → AS path only
Also in your diagram, you have ISP IBGP peers which wont work, they need to be towards ebgp peers.
res
Paul
Kind Regards
Paul
Hello Charles,
AS65535                    AS10                                AS20
It should be:
AS65535                    AS10                                 AS20
res
Paul
Kind Regards
Paul
Thanks....that did it.
