Remove PVDM4 Config from Router
Falco_Lombardi
We have a new router and need to remove the PVDM4 config. Been using a copy and paste of the config before but this new router does not have a PVDM4 module, its not needed. Think I got it figured out but wanted a second opinion as to what to remove so there is no unnecessary PVDM4 config. Attached the Cisco Router config to this discussion.
Cisco ISR4321/K9
I think all the stuff marked in bold can go:
Current configuration : 8441 bytes
version 15.6
no platform punt-keepalive disable-kernel-core
hostname DinubaRT
boot-start-marker
boot system bootflash:isr4300-universalk9.03.17.02.S.156-1.S2-std.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging queue-limit 10000
logging buffered 10000000
logging rate-limit 10000
no logging console
no logging monitor
enable secret 5 $1$FAp.$64yUoSWOtZnyycXANGAuf1
no aaa new-model
clock timezone PST -8 0
clock summer-time PDT recurring
ip multicast-routing distributed
no ip domain lookup
login on-success log
subscriber templating
--> trunk group 1
crypto pki trustpoint TP-self-signed-4210036560
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4210036560
revocation-check none
rsakeypair TP-self-signed-4210036560
crypto pki certificate chain TP-self-signed-4210036560
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34323130 30333635 3630301E 170D3230 30373134 31373330
32355A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32313030
33363536 30308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
0A028201 01009133 62F425EB 630DEA5B 53511678 71294A6C BFB280EF BC880157
587FE156 F76A5B64 9E0450F9 DC7025AE 0D5FDF57 4FBA3FDD 5B27BCFE 618804DF
94CFC432 858A89F5 A0B05D1B 080E00FE 154DA531 F82E5CD7 E98D40A1 8F70E030
A4B99790 BD56ED18 4AB7D630 932D1599 FEB5F10F BCBFC884 CAF174AC F42425BD
D3D64130 2CFF301E EBD21657 EC6D4604 6332314E B9B95413 28332CFF 7F9F58D8
A0914B46 11C8DF4C 5F28CAFF 84CF89B0 B647C935 E78E2ACB 317F90C4 5E76B6A1
2FB3F579 28485744 6A1C8B76 F5F36278 FADF7AC6 BAE458B0 5CF3B6C5 7C75001C
AB0EB8D5 FEC1FFFA BF315579 F25496B3 AF99D720 54E5BABE 66178B2B 1D0AA107
54DD81C5 4B390203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
301F0603 551D2304 18301680 142E2274 24A12E99 16CEE833 B9916ED6 AF342FDA
25301D06 03551D0E 04160414 2E227424 A12E9916 CEE833B9 916ED6AF 342FDA25
300D0609 2A864886 F70D0101 05050003 82010100 1FC9E29F C3BA83BD F5EFF3EB
5197F37D E8D4607B 71EAFD6E 26576B70 7364E5CF DF13D709 69946644 86EE198E
5710D92C 745CC7C8 0ED05B63 925E65CF 779B4305 A7D66855 11FDB7E8 DA55BFAA
6EAF9452 7E3CC7D6 B3910590 5564E531 59AF7956 6245C03F 6F8CA6A9 E1EE068D
E1AC2B83 8CB19CA8 988BB979 EB57AC59 CA9E41CA 369D2091 DD31BE3A CA247A86
10A2EFBA 79BA8BF9 61FCBD4A 3F1B9E62 7A8486A7 8EA1535F 1A604127 A9B68F1C
BBAE6C26 B4282ABE 9E306AAD 3940C676 F9B6C970 501F2AFB 8E67CCC2 81FC8A81
38067449 D8CE688A C8DBD2DB 504217D2 C0A939FE F610C29A 431CDEFD A648D084
78BD38D0 750BA941 BC2E23AE 2C8C8ECD 4A9F5152
quit
--> voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 display-ie ccm-compatible
sip
bind control source-interface GigabitEthernet0/0/0.2
bind media source-interface GigabitEthernet0/0/0.2
registrar server expires max 300 min 60
--> voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
--> voice class h323 1
h225 timeout tcp establish 3
--> voice iec syslog
--> voice register global
default mode
system message SRST Mode
max-dn 50
max-pool 25
--> voice register pool 1
id network 0.0.0.0 mask 0.0.0.0
codec g711ulaw
no vad
--> voice hunt-group 10 parallel
timeout 120
pilot 8581
preference 3 secondary 9
--> voice-card 0/1
no watchdog
--> voice-card 0/4
dsp services dspfarm
no watchdog
license udi pid ISR4321/K9 sn FLM241803LJ
license accept end user agreement
license boot level appxk9
license boot level uck9
license boot level securityk9
archive
log config
hidekeys
username uhcadmin privilege 15 secret 5 $1$jrR6$pBaDZG/IvFb2COp249QWq1
username telcion privilege 15 secret 5 $1$jDhj$t3WTnpqCo6w.02toKoUDG0
redundancy
mode none
vlan internal allocation policy ascending
interface Tunnel2
description ### Tunnel to Telcion###
ip address 172.31.250.174 255.255.255.252
ip pim sparse-mode
cdp enable
tunnel source GigabitEthernet0/0/0.2
tunnel destination 172.31.10.54
no ip address
negotiation auto
--> interface GigabitEthernet0/0/0.2
description ### Dinuba-VOIP-Phones-VLAN ###
encapsulation dot1Q 2
ip address 192.168.238.254 255.255.255.0
ip helper-address 192.168.76.54
ip helper-address 192.168.76.64
ip pim sparse-dense-mode
ip igmp version 3
no cdp enable
h323-gateway voip bind srcaddr 192.168.238.254
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip pim bidir-enable
ip pim rp-address 172.31.251.1 Telcion-Cloud-Paging
ip mroute 192.168.141.0 255.255.255.0 Tunnel2
no ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0.2
ip route 0.0.0.0 0.0.0.0 192.168.238.253
ip route 172.31.251.1 255.255.255.255 172.31.250.169 name Telcion-Cloud-Multicast
ip access-list standard Telcion-Cloud-Paging
ip sla responder
logging facility local6
logging host 192.168.76.57
logging host 192.168.76.59
snmp-server community public RO
snmp-server community write RW
control-plane
-> voice-port 0/1/0
trunk-group 1
connection plar 8581
description 559-591-2024
caller-id enable
--> voice-port 0/1/1
trunk-group 1
description 559-591-2022
caller-id enable
--> voice-port 0/1/2
trunk-group 1
description 559-591-2018
caller-id enable
--> voice-port 0/1/3
trunk-group 1
description 559-591-2019
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
--> sccp local GigabitEthernet0/0/0.2
sccp ccm 192.168.141.52 identifier 2 version 7.0
sccp ccm 192.168.141.53 identifier 1 version 7.0
sccp
--> sccp ccm group 1
bind interface GigabitEthernet0/0/0.2
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register Dinubaxcode
--> dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 16
associate application SCCP
--> dial-peer voice 199 pots
trunkgroup 1
incoming called-number .
--> dial-peer voice 9911 pots
trunkgroup 1
destination-pattern 9911
forward-digits 3
--> dial-peer voice 200 pots
trunkgroup 1
destination-pattern 9[2-8]11
forward-digits 3
--> dial-peer voice 201 pots
trunkgroup 1
destination-pattern 9[2-9]......
forward-digits 7
--> dial-peer voice 202 pots
trunkgroup 1
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
--> dial-peer voice 204 pots
trunkgroup 1
destination-pattern 9011T
prefix 011
--> dial-peer voice 205 voip
preference 1
destination-pattern [1-8]...
session target ipv4:192.168.141.52
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
--> dial-peer voice 206 voip
preference 1
session target ipv4:192.168.141.53
voice-class codec 1
voice-class h323 1
no vad
--> ephone-type word
device-type 8945
num-buttons 4
max-presentation 3
--> call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7960 2
ip source-address 192.168.238.254 port 2000
max-dn 100 dual-line
transfer-pattern .T
keepalive 20
call-forward pattern .T
time-zone 5
line con 0
password RtSwp@$$w0rd
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 30 0
privilege level 15
login local
transport preferred ssh
transport input ssh
ntp server pool.ntp.org
end
