Remove voice card
mariov652
By default our routers start up with their voice cards available.
If there is no need for this module to be loaded is there a "no voice card xyz" command available to disable the card(s)?
royalblues
Level 10
Level 10
Unfortunately cisco IOS does not allow you to enable and disable these type of services and hence if the IOS supports the card, the module will be loaded
Narayan
royalblues
Level 10
Level 10
Narayan
Thank for confirming so quickly.
