Replacement for Cisco 2851 Router (on the Edge)
What Cisco Router would be my best option to Replace my Cisco 2851 Router (on the Edge)
Thanx
balaji.bandi
it all depends on throughput you like to upgrade to a new model
suggest have a look at compare tool - based on the features :
https://www.cisco.com/c/en/us/products/routers/router-selector.html?oid=caten020272&target_deployments=branch
BB
Leo Laohoo
Depends on the WAN link and the budget.
So my Cisco 2851 is connected to my Surfboard 8200 Cable Modem (Internet-Spectrum -400Mbs down) and then connected to my Netgear GS724 Gigabit Switch (My All Gigabit Network)
So I would need a Router with 400Mbs Throughput and also I think it would need the ENTERPRISE Software so that I have Firewall.
what is the role of the router here ?  do your Surfboard 8200 Cable Modem - give you ethernet output, i would suggest to buy a Firewall than Router -  (this suggesting thinking that ISP handover ethernet with IP address ?)
BB
