Replacement of Backplane Cisco 7606
nocsertech
Hello
I have a CISCO7606 chassis. Recently I tried to insert a Sup720-3B with loose power connector while the Router in operation and cause the spark to my router. My router shutdown immediately. I tried to turn on again but the router fan run on top speed and the sound is loud but I still can console to the router. I suspect the back plane get damaged. I planned to replace the backplane. My question is, is there the backplane is replaceable item?
I tried to search from the Internet and ebay and so far no result found.
Vinit Jain
The backplane is not replaceable. You will have to replace the chassis if there is a failure.
Vinit
--Vinit
Vinit Jain
Vinit
--Vinit
Wow. The cost for my small mistake is too big.
