Replacing ISR G2 with LTE module
Im on the process of replacing an existing ISRG2 with LTE w/ C1111-4LTE. Im just wondering, what would be the requirements when i transfer the sim from the ISR G2 to the new router? Should i create a new profile on the new router? How do i copy the profile from the old router?
pieterh
1) the SIM must have the correct size (micro vs nano?)
2) some settings must match the provider
on the existing router start with "show cellular xxxxx profile"  and "show cellular xxxx firmware "
(or "show cellular xxxxx" all if you want everything at once)
this information is not found in the running-config
in the profile you may need to modify the APN
the firmware used may need to change, fortunately there is an "auto" mode
sho cel 0/1/0 firmware
Idx Carrier FwVersion PriVersion Status
1 ATT 02.32.11.00 002.070_002 Inactive
2 BELL 02.32.11.00 001.041_000 Inactive
3 GENERIC 02.33.03.00 002.072_000 Active
4 ROGERS 02.32.11.00 001.040_000 Inactive
5 SPRINT 02.32.11.00 002.062_001 Inactive
6 TELUS 02.32.11.00 001.040_000 Inactive
7 US-CELLULAR 02.32.11.00 000.039_002 Inactive
8 VERIZON 02.33.03.00 002.079_001 Inactive
Firmware Activation mode = AUTO
Just to verify, so i need to copy over the profile to new router right? How do we do that?
pieterh
I already mentioned the show commands to retrieve the current settings
then use a similar command on the new router
cellular 0/2/0 lte profile create 1 simstaticip.com
or
cellular 0/2/0 lte profile create 1 advancedinternet
