Require input on Cisco Lab Scenarios
tarique195
Hi All,
First off i am sorry if i am posting it in the wrong forum.
I have a couple of cisco devices and exploring possibilities of starting a small teaching institute.
For this i would need your inputs on various lab scenarios that is possible from the given below list of devices.
1) 800 Series Routers - 2
2) 2610 Series Routers - 2
3) 2 more Modular routers - 2
4) 2950 switch - 1
I need to know the possible lab scenario both at CCNA & CCNP Level.
Tarique
cadet alain
you need at least 3  2950 or 2 2950 and 1 3550 otherwise you won't be able to do much in switching.
Regards.
Alain
tarique195
Thanks Alain.
I will then look to purchase them.
