Requirement for IPV4 and work around
vicky.dhas
Friends,
One of my Financial Software Development customer has a requirement of Public IP’s
To connect to his end customer, my customer requires 1:1 NAT for each user. Any repeated request from Same Public IP is not accepted by end customer device. Because of which my customer has procured more than 3 x /24 IP pools and still need more. IPv4 is exhausting and his business has a problem because of same.
. DO we have a work around for same?
Bilal Nawaz
Wow x3 /24 pools of the Internet space is quite a lot in this day and age! I do not think there is any other work around other than to get more addresses somehow!? or change the infrastructure/end devices to allow PAT and single IP or IP's which would be far more efficient.
You could take a look at IPv6 but I think since they aren't coping getting IPv4 working with normal PAT it might be a struggle.
Maybe someone has experience of working with this type of scenario.
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Are you saying all your lan devices require 1:1 STATIC nat mapping and Dyamnic NAT is not applicable correct?
"Any repeated request from Same Public IP is not accepted by end customer device" -is this a client requirement or an application one?
How many total client devices are you talking about? -
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
